  • 1.  Upgrade from AP105s.
    Posted Feb 17, 2017 10:29 AM
    We want to upgrade a site to the latest and greatest. Like the instant software. What new set of AP's should we be looking at?
  • 2.  RE: Upgrade from AP105s.
    Posted Feb 17, 2017 10:50 AM
    It's probably best to speak with your Aruba partner to work out what APs are best for your environment.
    Here's a link to the APs you could purchase. Check out the product finder section to get an idea of what might be suitable however,I would 100% recommend getting an Aruba partner involved so you can ensure you get the correct quantity, model, etc..
