Comware
Upgrade HPE 1950 (JH295A) firmware
  • 1.  Upgrade HPE 1950 (JH295A) firmware
    Posted Jul 19, 2021 05:08 AM
    Hy!
    I have two HPE 1950 (JH295A) switch in IRF stack confiuguration. The current firmware is: 1950_12xgt-cmw710-boot-r5103p03 and 1950_12xgt-cmw710-system-r5103p03.
    What is the suitable firmware file to our switches on this site?
    https://techlibrary.hpe.com/OfficeConnect/?SKU=JH295A
    Below the Software for 10-Gigabit Aggregation Switch?
    Can I upgrade the switches on the GUI? I can access the IRF stacks virtual IP. Does it upgrade the two switch firmware? What is the correct upgrade process?
    Thanks.
    #irfstack
    #Firmwareupgrade
  • 2.  RE: Upgrade HPE 1950 (JH295A) firmware
    Posted Jul 19, 2021 06:08 AM
    'HPE 1950 Switch Series 7.10.R5106P06'  is the suitable software version for this device.
    Yes, thsi is suitable for 10gig aggrefation link.
    Refer release notes for it by below link:
    https://support.hpe.com/hpesc/public/docDisplay?docId=a00109606en_us
    You can do upgrade either via CLI or GUI.
    CLI upgrade process is available in release ntoes.
    Thanks!
  • 3.  RE: Upgrade HPE 1950 (JH295A) firmware
    Posted Jul 19, 2021 06:27 AM
    Thanks for You fast reply.
    When I start the upgrade procedure on the virtual ip of the irf stack, does it automatically upgrade the two member switch? Can I plan downtime during the upgrade? What is the upgrade process order?
  • 4.  RE: Upgrade HPE 1950 (JH295A) firmware
    Posted Jul 19, 2021 07:09 AM
    Yes, you to plan a downtime because need to reboot both devices.
    Upgrade via CLI using TFTP server.
    1. Download the software image where TFTP server installed.
    2. Set the ip on switch and transfer the file to switch flash via TFTP server.
    3. Set main image in both devices slot 1 and slot 2.
    4. Once image is set then save the config and reboot the switch.
    This will upgrade one by one.
    You can refer pg. 15 from release notes for upgrade steps via tFTP server.
    Similar way you can do it via GUI as well.
    Device-->Upgrade-->View Software images
    Go back to Device-->Upgrade-->Click on upgrade and upload the file into slot 1 and slot 2.
    Both slot sould have same file and set new image as main image in boot-rom before reboot.
    Thanks!
  • 5.  RE: Upgrade HPE 1950 (JH295A) firmware
    Posted Jul 19, 2021 09:08 AM
    I have another question. I downloaded the R5106P06 file, and it contains only .ipe file. I read the your attached document and there is a step 3, which conatin that upload the Boot ROM file from the tftp server, but there isn't this file. Where can I download it?
  • 6.  RE: Upgrade HPE 1950 (JH295A) firmware
    Posted Jul 19, 2021 09:25 AM
    Bootrom upgrade is not required into comware 7. You can ignore that step.
    Thanks!
  • 7.  RE: Upgrade HPE 1950 (JH295A) firmware
    Posted Jul 19, 2021 09:46 AM
    Thanks!
    Are there any rollback plan/steps if something is wrong during the frimware upgrade?
  • 8.  RE: Upgrade HPE 1950 (JH295A) firmware
    Posted Jul 19, 2021 10:50 AM
    For rollback, you can set running software as back-up image for both the slots.
    Thanks!
  • 9.  RE: Upgrade HPE 1950 (JH295A) firmware
    Posted Jul 19, 2021 02:13 PM
    Thanks, sorry for my question, but I am new in the HPE switches. How can I set it? I cannot find any information it.
  • 10.  RE: Upgrade HPE 1950 (JH295A) firmware
    Posted Jul 20, 2021 04:13 AM
    Hy!
    I find this on the IRF stack:
    Software images on slot 1:
    Current software images:
      flash:/1950_12xgt-cmw710-boot-r5103p03.bin
      flash:/1950_12xgt-cmw710-system-r5103p03.bin
    Main startup software images:
    Backup startup software images:
      None
    Software images on slot 2:
      None
    So the backup startup software images not set. Is it a risk during the firmware update? Should I set it to the:
    Thanks.
  • 11.  RE: Upgrade HPE 1950 (JH295A) firmware
    Posted Jul 20, 2021 05:09 AM
    Its better to save the running image as backup image.
    Proactively it is always advised to set the backup image.
    The image is already in flash, you just need to set as back up and new image as main image.
    Thanks!
  • 12.  RE: Upgrade HPE 1950 (JH295A) firmware
    Posted Jul 20, 2021 08:38 AM
    What is the correct commands to set the backup startup image?
  • 13.  RE: Upgrade HPE 1950 (JH295A) firmware
    Posted Jul 20, 2021 10:24 AM
    Try this command:
    boot-loader file boot flash:/1950_12xgt-cmw710-boot-r5103p03.bin system flash:/1950_12xgt-cmw710-system-r5103p03.bin all backup
    Thanks!
  • 14.  RE: Upgrade HPE 1950 (JH295A) firmware
    Posted Jul 21, 2021 03:39 AM
    Thanks.
  • 15.  RE: Upgrade HPE 1950 (JH295A) firmware
    Posted Jul 21, 2021 06:01 AM
    I have another question which is regarding to the firmware upgrade. The current firmware version is: 5103P03
    The latest update is: 5106P06
    Can I upgrade directly to the new version? There is an intermediate firmware between 5103P03 and 5106P06.
    Thanks.
  • 16.  RE: Upgrade HPE 1950 (JH295A) firmware
    Posted Jul 21, 2021 06:06 AM
    There is no intermediate version required.
    You can do direct upgrade to 5106P06.
    Thanks!
  • 17.  RE: Upgrade HPE 1950 (JH295A) firmware
    Posted Jul 23, 2021 02:47 AM
    Hy akg7!
    I succesfully upgrade our HPE 1950 IRF stack firmware! Thanks for Your professional help.
    Adam
  • 18.  RE: Upgrade HPE 1950 (JH295A) firmware
    Posted Jul 26, 2021 05:55 AM
    Hello @adam900331 ,
    It's good to hear that device is successfully upgraded. Cheers...:)
    Thanks!
