  • 1.  Upgrade Path 8.3.0.1_65474 to 8.5.0.4_72900 (Model AP-345)
    Posted Nov 18, 2019 03:36 PM
    Hey guys.
    Apologies as I did try to find the upgrade path documentation but I wasn't successful.
    Previous Airhead community member told me to check the AP Datasheets, but I can't find that info anywhere within the Datasheet:
    https://www.arubanetworks.com/assets/ds/DS_AP340Series.pdf
    I do suspect I can go straight to the upgraded firmware version but in reality want to verify and not assume as it is for a large corporate customer.
    Could someone please:
    1. Confirm if I can do the upgrade as per Post Subject
    2. Confirm where I am going wrong in not beign able to locate the upgrade paths?
    Thank you very much in advance.
    Ash
  • 2.  RE: Upgrade Path 8.3.0.1_65474 to 8.5.0.4_72900 (Model AP-345)
    Posted Nov 18, 2019 04:10 PM
    You can go to 8.5.0.4 from 8.3.0.1 because the IAP 345 supports it.  If this is a controller-based AP without an MM, you should do a backup flash on the controller and then upgrade.  If this is a controller-based AP WITH and MM, you should do a backup flash on the MM, then the MDs.  Next you will want to upgrade the MM to 8.5.0.4, first, and then the MDs.
  • 3.  RE: Upgrade Path 8.3.0.1_65474 to 8.5.0.4_72900 (Model AP-345)
    Posted Nov 18, 2019 04:42 PM
    Thanks for the update cjoseph.Appreciate the time taken to respond.
    Still would like if possible to understand why I cant locate where AP upgrade paths are if none show in the Datasheets.
    Ash.
  • 4.  RE: Upgrade Path 8.3.0.1_65474 to 8.5.0.4_72900 (Model AP-345)
    Posted Nov 18, 2019 05:20 PM
    The datasheets are static, EDIT: and show the minimum version of ArubaOS required to support that AP.  The release notes for every version of ArubaOS have a table of supported APS:
    Attachment(s)
