Network Management
  • 1.  Upgrading AirWave 7.5.7 question
    Posted Aug 12, 2014 10:33 AM
    We are running version 7.5.7 with CentOS 5.5. How do you go up to the latest that appears when I log into the server (8.0.1)?
  • 2.  RE: Upgrading AirWave 7.5.7 question
    Posted Aug 12, 2014 09:11 PM
    Tech support said you have to go to 7.6.5 (5.5) ->7.6.5 (6.2)->7.7.12. He said it 8.0.1 was available but it was taken down and is being worked on. It should be ready soon. He suggested to go to 7.7.12.
  • 3.  RE: Upgrading AirWave 7.5.7 question
    Posted Aug 14, 2014 11:03 AM
    Keep in mind that the OS upgrade step is the tricky part.
    Upgrade from 7.5.7 -> 7.6.5 is straight forward
    Then you need to take a backup and pull the backup off the server
    Reinstall fresh from the 7.6.5 ISO
    Restore the backup
    Then upgrade to 7.7.12
    8.0.3 should be available soon, it's still in testing.
  • 4.  RE: Upgrading AirWave 7.5.7 question
    Posted Aug 14, 2014 11:25 AM
    I followed the steps from tech support. I haveattached them for anyone else that's needs to do this type of upgrade.
