Hi!
Example (Logical interface lag1 made of physical interfaces 1/1/49 and 1/1/50):
interface lag 1
no shutdown
description lag1 uplink to trk5 Aruba 2530
no routing
vlan trunk native 1
vlan trunk allowed 1,2,3,144,... <--- place here the full list of (existing) VLANs you need to allow on the lag1 [*]
lacp mode active
spanning-tree loop-guard
interface 1/1/49
no shutdown
mtu 9100
description Interface-1-1-49-lag1
lag 1
interface 1/1/50
no shutdown
mtu 9100
description Interface-1-1-50-lag1
lag 1
You should use similar interfaces on Aruba CX 6000 side, the type and speed should be identical on both ends (e.g. a pair of 1 Gbps optical Short Range Transceivers on Aruba 2530 side and a pair of 1 Gbps optical Short Range Transceivers on Aruba CX 6000 side).
[*] At Aruba 2530 side check with show vlan ports ethernet Trk5 detail to see the VLANs membership of the trk5 logical interface.
Original Message:
Sent: Apr 14, 2025 06:43 AM
Subject: Upling trunking with LACP CX 6000 with 2530
Hello!
I'm trying to build a trunked uplink with a HPE 2530 and CX 6000 switch. The 2530 is configured as below.
HP-2530-48G-PoEP 14-Apr-2025 12:31:55
===========================- TELNET - MANAGER MODE -============================
Switch Configuration - Port/Trunk Settings
Port Type Enabled Mode Flow Ctrl Group Type
51 1000SX | Yes Auto Disable Trk5 LACP
52 1000SX | Yes Auto Disable Trk5 LACP
HP-2530-48G-PoEP 14-Apr-2025 12:34:51
Switch Configuration - VLAN - VLAN Port Assignment
Port DEFAULT_VLAN Management WLAN_GAST DMZ Testnetz
Trk5 | Untagged Tagged Tagged No No
Where Default_VLAN = 1; Management = 2; WLAN_GAST = 3; DMZ = 144; Testnetz = 145; vMotion = 192
How is this configuration done with the CX 6000 switch as the menu function in CLI is missing?
