  • 1.  USB 3G/4G compatibility with IAP-114
    Posted May 12, 2015 10:23 AM
    I have following question: Is huawei E3372 comatible with IAP-114. I would like to configure this 3g/4g modem as uplink connection.
    Additionally I would like to know where can I find the file which 3g/4g modems are comatible with aruba ap.
    Thanks in advance!
    Mateusz
  • 2.  RE: USB 3G/4G compatibility with IAP-114
  • 3.  RE: USB 3G/4G compatibility with IAP-114
    Posted May 12, 2015 10:33 AM
    Hi!
    Thank you very much for this information. Unfortunatelly I cannot find my 3/4G modem. It means that the IAP does not detect this device?
    Additionally, Could you confirm thaht IAP-114 is able to work with 3g/4g uplink connection.
    Mateusz
  • 4.  RE: USB 3G/4G compatibility with IAP-114
    Posted May 12, 2015 10:35 AM
     It may work, but there is no supported configuration. You should swap the dongle for one of the ones on the supported list.
    Yes, Instant AP's with USB ports support USB modem uplink.
  • 5.  RE: USB 3G/4G compatibility with IAP-114
    Posted May 17, 2015 06:59 PM
    Hi
    as said by cappali all usb AP supports 3g/4g modem.
    now you have 3 choise
    1. bay a USB modem listed in the compatibility table
    2. use 3G/4G modem with ethernet ports
    3. open a TAC case and wait until they add your USB modem to the comatibility list (it may takes months)
    Regards
  • 6.  RE: USB 3G/4G compatibility with IAP-114
    Posted May 17, 2015 07:02 PM
    Another option is to use a cradlepoint.
  • 7.  RE: USB 3G/4G compatibility with IAP-114
    Posted May 18, 2015 03:45 AM
    Thanks for all informations. I have already tried to connect Huawei E173 dongle to RAP-155P. But unfortunately the dongle does not work. Below you will find my configuration:
    cellular-uplink-profile
    usb-type option usb-dev 0x12d11c05
    usb-tty ttyUSB0 usb-init AT+CGDCONT=1,"IP","internet"
    usb-user internet
    usb-passwd internet
    usb-dial ATD*133#
    usb-modeswitch "-v 0x12d1 -p 0x1c0b -M 55534243123456780000000000000011062000000100000000000000000000 -RIn"
    I live in Poland and I use Orange Poland which is a Polish telecommunications provider.
    So this is the reason why I configured following settings:
    usb-user internet
    usb-passwd internet
    usb-dial ATD*133#
    RAP-155P has the 6.4.2.3-4.1.2.1_49445 firmware version.
    Mateusz
