As far as I know, the AP-654 (and 635) is only shipping in a handful of countries that allow 6GHz connectorized APs, for which I have seen the list US, Canada, Australia, New Zealand. Which means that the AP is probably not even shipping to the UK, and if it is, the 6GHz radio will be disabled by DRT.
I'm not aware of UK regulations on the use of external antenna's on 6GHz, but if the regulator (seems to be Ofcom for UK) allows it, it can be enabled and 634/654 APs may start shipping to the UK. Your local Aruba Sales Team may be the best to ask this question; unless someone here has more information.
Original Message:
Sent: Dec 21, 2023 05:25 AM
Subject: Use of AP-654 in UK
What is the timeline for using the AP-654 with connectorised antennas in the UK for usage on the 6GHz band (indoor usage)? It looks like the AP is available to purchase does this also mean that it has been approved for the above usage?
