  • 1.  used IAP returns wrong map location
    Posted Dec 07, 2016 03:37 PM
    Purchased used IAP's, did a factory reset, and installed ok.  However, IOS location services and PC map applications return wrong address.  I assume it was the previous location for these IAP's.  How do I teach them the right location?
  • 2.  RE: used IAP returns wrong map location
  • 3.  RE: used IAP returns wrong map location
    Posted Dec 08, 2016 11:01 AM
    I didn't see a solution in the link that was responded.  I did see a refernece to "advertise-location enabled in the WLAN SSID Profile"   But I don't find that setting in the virtual controller.  Any other clues?
  • 4.  RE: used IAP returns wrong map location
    Posted Dec 08, 2016 11:41 AM
    Advertise-location is not related to what you are trying to do.  In the thread there is a link that says how to opt out of location services by changing your SSID name.
  • 5.  RE: used IAP returns wrong map location
    Posted Dec 08, 2016 12:09 PM
    Thanks, but I didn't see a link to what you referenced to opt out of location services by changing SSID.  Please resend the link.
