  • 1.  Username/password for Guest users
    Posted Apr 28, 2015 03:15 AM
    Can we set time for Guest username and password to expire after certain time?
  • 2.  RE: Username/password for Guest users
    Posted Apr 28, 2015 05:35 AM
    HI,
    Yes. it is possible. BTW are you using internal db or any external db for the guest accounts ?
    for your ref , how to set the expiry for a guest ,
    Hope you got your solution, if not feel free for any further help on this.
  • 3.  RE: Username/password for Guest users
    Posted Apr 28, 2015 05:45 AM
    Thanks Venu, i am assuming this is in Instant OS, i dont have one to play with should get one next week, hence asking :)
    And using internal DB
  • 4.  RE: Username/password for Guest users
    Posted Apr 28, 2015 05:47 AM
    Sorry James saw your reponse after my post
  • 5.  RE: Username/password for Guest users
    Posted Apr 28, 2015 05:38 AM
    Instant: No
    Controller: Yes
    ClearPass: For sure.
    Cheers
    James
