Using a Wireless G PCMCIA card with the HP Compaq nx9005 laptop
  • 1.  Using a Wireless G PCMCIA card with the HP Compaq nx9005 laptop
    Posted Mar 02, 2004 09:04 AM
    Has anyone else run into this problem? I recently upgraded my home wireless system to G (router and NIC). I have tried both the MICROSOFT MN720 PCMCIA 802.11g wireless NIC and the D-Link DWL-G650. Both are unable to consistantly recognize my G wireless network. After investigating with the manufacturers of the cards and the router it turns out that the problem is that the PCMCIA card slot of the nx9005 is to noisy for G wireless. 802.11b works just fine. Is anyone else using a PCMCIA G wireless card with the nx9005 successfully?
  • 2.  RE: Using a Wireless G PCMCIA card with the HP Compaq nx9005 laptop
    Posted Jun 24, 2004 02:45 AM
    Did you have any luck?
    I am trying to install the DWL-G650+ and I cannot get my nx9005 to start it (even power it up)
    Works fine on my old Armada E500!
    Any advice would be gratefully appreciated.
    Cheers
    Scott
