  • 1.  Using Aruba Access Point Through RADIUS Server
    Posted 7 days ago
    Currently, I have 13 of Aruba Access point models between 207 - 303 and one of them is acting as a controller. I am trying to configure SSID so my users can connect it via certificate, but I couldn't trust the AP with my CA server, and I don't know how to create AP certificate to be trusted via CA server.
    Hereunder a screenshots of my configuration
  • 2.  RE: Using Aruba Access Point Through RADIUS Server
    Posted 7 days ago
    Edited by Herman Robers 7 days ago
    You don't need your AP to be trusted. The client needs to be configured to trust the EAP (NPS in your case) certificate. For EAP-TLS (Smart card or other certificate), you would need to configure your RADIUS sever (NPS in your case) to trust the client certificate deployed to your clients.
    With EAP/RADIUS, the AP is just relaying/transporting, it's not actively taking part in the authentication which happens between client and RADIUS server.
  • 3.  RE: Using Aruba Access Point Through RADIUS Server
    Posted 7 days ago
    Hi Robers,
    First, I would like to thank you for your quick response, but I unfortunately still facing same issue that the user couldn't obtain the required certificate
    I have managed to export the RADIUS cert from CA server then import it on the client machine for both user and computer certificate.
    I would be appreciated if you could provide me with a specific steps to follow
  • 4.  RE: Using Aruba Access Point Through RADIUS Server
    Posted 6 days ago
    Assuming this message comes from the client.
    You should not export the RADIUS EAP certificate, but the Root CA that issued that certificate; then import it in the client and configure that Root CA in the supplicant (client) configuration as one of the trusted CAs. Also, make sure that the RADIUS EAP certificate is CA issued (not self-signed!), but the CA may be your private CA.
    I don't know NPS well enough to provide specific steps; but the approach is the same: client needs to trust the server by importing the RADIUS server EAP certificate's Root CA, server needs to trust the client by importing the Client Root CA into your RADIUS server.
