Network Management
  • 1.  Using HPE intelligent management center as an NTP server
    Posted Sep 02, 2020 05:16 AM
    Is it possible to using HPE intelligent management center as an NTP server for my devices?
    If I can use it as a NTP Server -how to enable it?
    Any other good suggestion if this is not posible?
    //Jan-Erik
  • 2.  RE: Using HPE intelligent management center as an NTP server
    Posted Sep 03, 2020 12:38 AM
    @Eikefjord
    I do not think there is any such option on IMC to configure it as NTP server.
    May be you can consider configuring the Windows/Linux machine as NTP server on which the IMC is installed.
  • 3.  RE: Using HPE intelligent management center as an NTP server
    Posted Sep 08, 2020 05:26 AM
    @Eikefjord  Hi, just wanted to check if you could manage to configure the NTP on windows/linux server
