Wired Intelligent Edge
Using SCP in ArubaOS-Switch
This thread has been viewed 68 times
  • 1.  Using SCP in ArubaOS-Switch
    Posted Oct 08, 2018 03:05 PM
    Did you know ArubaOS-Switch supports SCP?  Using an external SCP client, config files and firmware can be copied to and from the switch.
    Here's how it works:
    To begin you'll need an external SCP client, for this example I used pscp, which is a putty-based windows client.  As pscp is windows-based, it needs to be run from the windows command line.  First, you will need to enable the following commands on the switch:
    Switch(config)# ip ssh
    Switch(config)# ip ssh filetransfer
    After enabling the previous commands, you are then able to copy config files from the switch like so:
    c:\pscp>pscp admin@10.5.8.4:/cfg/testcfg.cfg <directory to copy files>
    Using keyboard-interactive authentication.
    admin@10.5.8.4's password:
    testcfg.cfg               | 1 kB |   1.6 kB/s | ETA: 00:00:00 | 100%
    You can copy files to the switch (default-config, startup-config, running-config only):
    c:\pscp>pscp -scp <file to copy in pscp directory> admin@10.5.8.4:/cfg/default-config
    testcfg2.cfg              | 1 kB |   1.6 kB/s | ETA: 00:00:00 | 100%
    Finally, you can update the firmware on the switch:
    c:\pscp>pscp -scp KB_16_07_0002.swi admin@10.5.8.4:/os/secondary
    KB_16_07_0002.swi         | 32969 kB | 578.4 kB/s | ETA: 00:00:00 | 100%
    Justin
  • 2.  RE: Using SCP in ArubaOS-Switch
    Posted Oct 09, 2018 08:59 PM
    More information about SCP you can find it in the "Files Transfer" chapter of the Management and Configuration Guide for your ArubaOS-Switch.
    e.g. look at chapter 16 page 350 of this guide:
    https://support.hpe.com/hpsc/doc/public/display?docId=a00050273en_us
    Regards
    Pedro
  • 3.  RE: Using SCP in ArubaOS-Switch
    Posted Mar 01, 2020 10:12 AM
    ArubaOS-CX seems not to have the possibility to backup with
    scp manager@10.10.10.10:/cfg/startup-config .
    Why was scp removed? (not implemented)
  • 4.  RE: Using SCP in ArubaOS-Switch
    Posted Mar 01, 2020 10:21 PM
    Good day!
    Yes you are correct.
    • As per today, Aruba ArubaOS-CX (AOS-CX) doesn’t support SCP(client/server).
    • TFTP/SFTP Client is supported on AOS-CX.  Does this help?
    Yash
  • 5.  RE: Using SCP in ArubaOS-Switch
    Posted Mar 02, 2020 04:00 AM
    in a PVOS / Comware environment built on iMC using scp that is an inconvenient exception.
    Winfried
  • 6.  RE: Using SCP in ArubaOS-Switch
    Posted Mar 02, 2020 05:07 AM
    Thank you for that feedback.
    Please talk to account team, will also send this request to our switching PLM. If I hear more update, will keep you posted.
    Due to this are you seeing any impact on current customer deal?
    or is this a must support feature for RFP?
    Please share, that will help me while sending request.
    Yash
  • 7.  RE: Using SCP in ArubaOS-Switch
    Posted Mar 02, 2020 05:13 AM
    Sure. We stop buying further ArubaOS-CX switches and look for other solutions so long.
  • 8.  RE: Using SCP in ArubaOS-Switch
    Posted Mar 02, 2020 07:33 AM
    it is for backup the config ? (or restore a config ?)
  • 9.  RE: Using SCP in ArubaOS-Switch
    Posted Mar 02, 2020 07:47 AM
    It is mainly backup, but also restore. A manual way is to do a copy running-config sftpurl from the CLI of the switch. iMC support case is already running for some time. CX is the only switch we use not supporting scp. I assume this is still the most common way. Am I wrong?
  • 10.  RE: Using SCP in ArubaOS-Switch
    Posted Mar 02, 2020 08:59 AM
    Alternatively we have scp supported on shell, does that help for now?
    CX6300#start-shell
    CX6300:/home/admin# scp vsrmsgs chandjol@10.0.15.237:/users/chandjol/supportfile/varmsgs
    chandjol@10.0.15.237's password:
    vsrmsgs 100% 859KB 60.3MB/s 00:00
    CX6300:/home/admin#
    btw, I am sharing your feature request to PLM. Will keep you posted on update asap.
    Have a good day!
    Thank you,
    Yash
  • 11.  RE: Using SCP in ArubaOS-Switch
    Posted Mar 02, 2020 09:53 AM
    There is also API for download (or upload) config and it is possible to call SCP destination (or source)
  • 12.  RE: Using SCP in ArubaOS-Switch
    Posted Mar 02, 2020 10:05 AM
    I am aware of scp in the root shell. This is a good way to work around other bugs.
    I was not aware of the API approach to export a configuration. Will iMC be capable of using the API?
    Cheers
    Winfried
  • 13.  RE: Using SCP in ArubaOS-Switch
    Posted Mar 06, 2020 01:22 AM
    No for IMC
  • 14.  RE: Using SCP in ArubaOS-Switch
    Posted Mar 06, 2020 06:11 AM
    If I understand the indication from support correctly there is no known solution at all to backup ArubaOS-CX with iMC.
    Has anybody managed?
  • 15.  RE: Using SCP in ArubaOS-Switch
    Posted Mar 06, 2020 08:17 AM
    Hello Winfried, on the contrary...I'm currently able to backup both of our Aruba 8320 switches (ArubaOS-CX) into HPE IMC...don't know if that is "on-topic" or "off-topic" considering your were discussing about using SCP on ArubaOS-Switch based switches...in any case have a look at the thread How to backup Aruba 8400 series switch with IMC 7.3 E0703 on HPE Networking Community forum (ArubaOS-CX backup via TFTP in HPE IMC).
  • 16.  RE: Using SCP in ArubaOS-Switch
    Posted Mar 06, 2020 08:27 AM
    Hello Parnassus,
    thanks for the hint with the other tftp base discussion thread concerning ArubaOS-CX iMC backup.
    Sorry for hijacking this thread on from ArubaOS-Switch to ArubaOS-CX.
    Cheers
    Winfried
