Requirement would be that you have those VCs in the same group.
If you configure an SSID at the group level it will be deployed to all VCs in that group.
At the same time you can also creat an SSID at the at the VC-level by navigating to the VC Configuration Dashboard and configure an SSID there:
https://help.central.arubanetworks.com/latest/documentation/online_help/content/access-points/mrt/vc-nav.htm------------------------------
Oliver Wehrli
Original Message:
Sent: Oct 08, 2020 12:55 AM
Subject: Utilizing the same WLANs across multiple VCs?.
We have a large number of Central managed Instant access points deployed over multiple sites and we need to have unique WLANs as well as common WLANs at each site. Is there an easy way to create a single WLAN that can be assigned to multiple VCs? ....
thanks
alexsunny
