Comware
  • 1.  Verifying 5900_5920-cmw710-system-r2432p06.bin failed
    Posted Sep 04, 2018 03:06 PM
    Hi Experts,
    i have failed message while verifing of .bin in slot 3 (i use IRF with 3 switchs)
    i chekced Space and no problem: slot3#flash: 524288 KB total (349396 KB free)
    Any one help.
    Thank you
    <sw04>boot-loader file flash:/5900_5920-CMW710-R2432P06.ipe slot 1 main
    Verifying the file flash:/5900_5920-CMW710-R2432P06.ipe on slot 1..........Done.
    HPE 5900AF-48XGT-4QSFP+ Switch images in IPE:
      5900_5920-cmw710-boot-r2432p06.bin
    This command will set the main startup software images. Continue? [Y/N]:y
    Add images to slot 1.
    Decompressing file 5900_5920-cmw710-boot-r2432p06.bin to flash:/5900_5920-cmw710-boot-r2432p06.bin..........................Done.
    Decompressing file 5900_5920-cmw710-system-r2432p06.bin to flash:/5900_5920-cmw710-system-r2432p06.bin.........................................................................................................................................................Done.
    Verifying the file flash:/5900_5920-cmw710-boot-r2432p06.bin on slot 1...Done.
    Verifying the file flash:/5900_5920-cmw710-system-r2432p06.bin on slot 1.........Done.
    The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 1.
    Decompression completed.
    You are recommended to delete the .ipe file after you set startup software images for all slots.
    Do you want to delete flash:/5900_5920-CMW710-R2432P06.ipe now? [Y/N]:y n
    <sw04>
    <sw04>boot-loader file flash:/5900_5920-CMW710-R2432P06.ipe slot 2 main
    Add images to slot 2.
    Decompressing file 5900_5920-cmw710-boot-r2432p06.bin to slot2#flash:/5900_5920-cmw710-boot-r2432p06.bin...................................Done.
    Decompressing file 5900_5920-cmw710-system-r2432p06.bin to slot2#flash:/5900_5920-cmw710-system-r2432p06.bin.................................................................................................................................................................................................................................Done.
    Verifying the file flash:/5900_5920-cmw710-boot-r2432p06.bin on slot 2....Done.
    Verifying the file flash:/5900_5920-cmw710-system-r2432p06.bin on slot 2.................Done.
    The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 2.
    Do you want to delete flash:/5900_5920-CMW710-R2432P06.ipe now? [Y/N]:n
    <sw04>
    <sw04>boot-loader file flash:/5900_5920-CMW710-R2432P06.ipe slot 3 main
    Add images to slot 3.
    Decompressing file 5900_5920-cmw710-boot-r2432p06.bin to slot3#flash:/5900_5920-cmw710-boot-r2432p06.bin...................................Done.
    Decompressing file 5900_5920-cmw710-system-r2432p06.bin to slot3#flash:/5900_5920-cmw710-system-r2432p06.bin...................................................................................................................................................................................................................................Done.
    Verifying the file flash:/5900_5920-cmw710-boot-r2432p06.bin on slot 3....Failed.
    flash:/5900_5920-cmw710-boot-r2432p06.bin on slot 3 is corrupted.
    Verifying the file flash:/5900_5920-cmw710-system-r2432p06.bin on slot 3.................Failed.
    flash:/5900_5920-cmw710-system-r2432p06.bin on slot 3 is corrupted.
  • 2.  RE: Verifying 5900_5920-cmw710-system-r2432p06.bin failed
    Posted Sep 04, 2018 06:10 PM
    It looks like you dind't use ISSU Software Upgrade (nor for testing the update nor for executing the update sequencially on IRF Members) to upgrade your 3 Members IRF deployment.
    I would suggest to list slot 3 flash's directory, clean slot 3 flash's directory contents from unused object such as older (and actual) ipe files and (corrupted) new bin files recently transferred from slot 1 (not just trashing but delete permanently), check free space left on slot 3 (it should be at least the double of the size of ipe file so, in your case, something like 180 MB). Check ipe file validity (before transfer to the Switch you can calculate zip file Hash value [*] and verifiy if it copes with the one published by HPE) and, once all is OK, retrasfer into slot 1 the ipe file you're going to use into slot 3 and transfer manually to slot 3 as you already did. Check if file corruption (on decompressed files) persist or not.
  • 3.  RE: Verifying 5900_5920-cmw710-system-r2432p06.bin failed
    Posted Sep 05, 2018 04:49 AM
    Hello parnassus,
    First i want to Thank you for your reply!
    Actually i didn't use ISSU because it's a new IRF with new switchs (no flow production right now).
    That's strange for me because this .ipe passed in slot1 (HPE 5900AF-48XGT-4QSFP+) and slot2 (HPE 5900AF-48XGT-4QSFP+) but not in slot3 (HPE 5900AF-48G-4XG-2QSFP+)n the 3rd switc his not the same model but i think it share the same version Comware OS.
    i did your instructions (delete ipe files, ew bin files recently transferred from slot 1) and i see the same problem.
    >dir  slot3#flash:
    Directory of slot3#flash:
       0 -rw-    11755520 Aug 31 2017 16:00:00   5900_5920-cmw710-boot-r2432p05.bin
       1 -rw-    76951552 Aug 31 2017 16:00:00   5900_5920-cmw710-system-r2432p05.bin
       2 drw-           - Jan 01 2011 00:00:26   diagfile
       3 -rw-        1311 Jan 01 2011 04:16:32   hostkey
       4 -rw-        4920 Jan 11 2011 23:58:40   ifindex.dat
       5 drw-           - Jan 01 2011 00:00:26   license
       6 drw-           - Jan 01 2011 03:43:26   logfile
       7 drw-           - Jan 01 2011 00:00:26   seclog
       8 -rw-         591 Jan 01 2011 04:16:33   serverkey
       9 -rw-       19425 Jan 11 2011 23:58:41   startup.cfg
      10 -rw-      259066 Jan 11 2011 23:58:47   startup.mdb
      11 drw-           - Jan 01 2011 00:00:54   versionInfo
    524288 KB total (436168 KB free)
    Verifying the file flash:/5900_5920-CMW710-R2432P06.ipe on slot 1...........Done.
    Decompressing file 5900_5920-cmw710-boot-r2432p06.bin to slot3#flash:/5900_5920-cmw710-boot-r2432p06.bin....................................Done.
    Decompressing file 5900_5920-cmw710-system-r2432p06.bin to slot3#flash:/5900_5920-cmw710-system-r2432p06.bin..................................................................................................................................................................................................................................Done.
    Verifying the file flash:/5900_5920-cmw710-system-r2432p06.bin on slot 3...............Failed.
    >dir  slot3#flash:
       1 -rw-    11755520 Jan 13 2011 00:13:11   5900_5920-cmw710-boot-r2432p06.bin
       2 -rw-    76951552 Aug 31 2017 16:00:00   5900_5920-cmw710-system-r2432p05.bin
       3 -rw-    76964864 Jan 13 2011 00:16:57   5900_5920-cmw710-system-r2432p06.bin
       4 drw-           - Jan 01 2011 00:00:26   diagfile
       5 -rw-        1311 Jan 01 2011 04:16:32   hostkey
       6 -rw-        4920 Jan 11 2011 23:58:40   ifindex.dat
       7 drw-           - Jan 01 2011 00:00:26   license
       8 drw-           - Jan 01 2011 03:43:26   logfile
       9 drw-           - Jan 01 2011 00:00:26   seclog
      10 -rw-         591 Jan 01 2011 04:16:33   serverkey
      11 -rw-       19425 Jan 11 2011 23:58:41   startup.cfg
      12 -rw-      259066 Jan 11 2011 23:58:47   startup.mdb
      13 drw-           - Jan 01 2011 00:00:54   versionInfo
    524288 KB total (349392 KB free)
  • 4.  RE: Verifying 5900_5920-cmw710-system-r2432p06.bin failed
    Posted Sep 05, 2018 05:09 AM
    I suspect that your slot 3's flash is going to need at least double of 117MB+78MB=195MB so at least - about - 390MB as free space to perform the update...and slot 3 has about 350MB only...if I read correctly reported values (flash in slot 3 contains also the old - current -  5900_5920-cmw710-boot-r2432p05.bin and  5900_5920-cmw710-system-r2432p05.bin files and this lower the free space).
    Flashes of slot 1 and 2 look the same in terms of files list and free space?
  • 5.  RE: Verifying 5900_5920-cmw710-system-r2432p06.bin failed
    Posted Sep 05, 2018 05:19 AM
    Here flashes space in all slots:
    >dir slot1#flash:/
    Directory of flash:
       0 -rw-    88727552 Mar 23 2018 18:02:40   5900_5920-CMW710-R2432P06.ipe
       1 -rw-    11755520 Aug 31 2017 16:00:00   5900_5920-cmw710-boot-r2432p05.bin
       2 -rw-    11755520 Jan 12 2011 00:37:40   5900_5920-cmw710-boot-r2432p06.bin
       3 -rw-    76951552 Aug 31 2017 16:00:00   5900_5920-cmw710-system-r2432p05.bin
       4 -rw-    76964864 Jan 12 2011 00:40:13   5900_5920-cmw710-system-r2432p06.bin
       5 drw-           - Jan 02 2011 00:00:43   diagfile
       6 -rw-        1311 Jan 01 2011 00:03:43   hostkey
       7 -rw-        4920 Jan 11 2011 23:58:40   ifindex.dat
       8 -rw-           0 Jan 12 2011 04:29:04   lauth.dat
       9 drw-           - Jan 01 2011 00:00:43   license
      10 drw-           - Jan 01 2011 05:17:06   logfile
      11 drw-           - Jan 01 2011 00:00:43   seclog
      12 -rw-         591 Jan 01 2011 00:03:43   serverkey
      13 -rw-       19425 Jan 11 2011 23:58:41   startup.cfg
      14 -rw-      259066 Jan 11 2011 23:58:42   startup.mdb
      15 drw-           - Jan 01 2011 00:01:11   versionInfo
    524288 KB total (262372 KB free)
    >dir slot2#flash:/
    Directory of slot2#flash:
       1 -rw-    11755520 Jan 12 2011 00:42:33   5900_5920-cmw710-boot-r2432p06.bin
       3 -rw-    76964864 Jan 12 2011 00:46:17   5900_5920-cmw710-system-r2432p06.bin
       4 drw-           - Jan 01 2011 00:00:43   diagfile
       5 -rw-        1311 Jan 01 2011 04:17:16   hostkey
       7 drw-           - Jan 01 2011 00:00:43   license
       8 drw-           - Jan 01 2011 00:13:06   logfile
       9 drw-           - Jan 01 2011 00:00:43   seclog
      10 -rw-         591 Jan 01 2011 04:17:17   serverkey
      12 -rw-      259066 Jan 11 2011 23:58:45   startup.mdb
      13 drw-           - Jan 01 2011 00:01:11   versionInfo
    524288 KB total (348596 KB free)
    >dir slot3#flash:/
