Aruba Apps
Via authentication Successful but Via client not connecting
  • 1.  Via authentication Successful but Via client not connecting
    Posted Oct 13, 2016 12:12 PM
    Hi All,
    I've got a problem where I'm configuring Via to authenticate against ClearPass.
    The Via client is authenticates and I see a successul auth in CPPM & a user in the correct role on the controller. I would expect the Via client to be connected at this point but it fails to connect and re-prompts the user to select a cert for authentication.
    All the certificates used are from the same CA.
    Via clients tested 2.3.3 & 2.3.4. (Windows)
    Controller version 6.4.3.9
    CPPM Version: 6.6.2
    Have tried EAP-MSCHAPv2 and EAP-TLS
    Though it'd mention it on here to see if someone had a similar issue?
    Cheers
    James
