Recently, I have been trying to use VIA and I could never get the client workstation to connect. I'm using very basic crypo maps and preshared keys to try and get this going. I do not have DNS going at the moment.
Setup
Client ---- PAN Firewall ----- Controller
Workstation OS - Windows 7
Client - Aruba VIA client 3.2
PAN Firewall Config - Virtual Wire Setup with an Allow All Policy
Controller - Aruba 7205 with ArubaOS 6.5.4 FIPS (FIPS disabled)
I set the auto retry to 30 and noticed the following:
Datapath session Table
Using ports 443 and 4500
The controller is responding but the client continues to flood the controller. Doesn't seem to be recieving or reconizing a response.
ISAKMP SA
Phase 1 is completed - Internal IP is assigned
L2TP Local Pool
5 IPs are assigned (only have the one client connecting)
IPSEC SA
Phase 2 is completed.... for about 40 different SAs same external IP different internal IP
Has anyone seen something like this before or has an idea of where to check?
