  • 1.  Via EAP-TLS with Machine cert
    Posted Oct 05, 2016 12:57 PM
    Hi All,
    Is it possible to do this?
    Via EAP-TLS authentication using the client Machine certificate.
    Cheers
    James
  • 2.  RE: Via EAP-TLS with Machine cert
    Posted Oct 05, 2016 05:11 PM
    Yes.
    Setup a Group policy that distributes machine certificates
    Setup a Group policy that does only machine authentication.
  • 3.  RE: Via EAP-TLS with Machine cert
    Posted Oct 16, 2016 09:33 PM
    Isn't he asking about VIA?
    The VIA client does not check the machine store when a user is logged in, although it checks the machine store before user login if you have "domain pre-connect" enabled.
  • 4.  RE: Via EAP-TLS with Machine cert
    Posted Oct 17, 2016 04:27 AM
     I was talking about Via and I've configured it now so all good. :)
    VIa checks the local certificate store on the machine. Client and machine certs are stored there and can both be used.
