  • 1.  VIA vpn - machine authentication
    Posted Mar 19, 2020 08:24 PM
    Hello GURUs,
    I went through VIA appnote, and I didn't find the answer to the below question,
    Can we do machine authentication through VIA vpn? if so can we do that?
    In addition, I have basically 3 connection profiles, each with specific setup, is there a way to show only a specific profile for specific users?
  • 2.  RE: VIA vpn - machine authentication
    Posted Mar 19, 2020 10:50 PM
    Domain pre-connect is the "machine authentication" you might be looking for:  https://community.arubanetworks.com/t5/Controller-Based-WLANs/What-is-Domain-Pre-connect-in-VIA-and-how-does-it-work/ta-p/184550
    https://community.arubanetworks.com/t5/Wireless-Access/VIA-Pre-Connect-option/td-p/114155
    EDIT;  Please see the attached document for details on configuring VIA.
    Attachment(s)
    pdf
    via-3x-configuration.pdf   1.13 MB 1 version
  • 3.  RE: VIA vpn - machine authentication
    Posted Mar 20, 2020 07:45 AM
    Nice docs reference,
    I can see the feature is supported just with IKEv2, I'm currently using IKEv1 with MFA, so pre-conn won't work for my case?
    Besides, I think Pre-conn option won't prevent a non-domain PC from being connected to the VPN, right?
    Thanks.
  • 4.  RE: VIA vpn - machine authentication
    Posted Mar 20, 2020 07:55 AM
    It is only supported with IKEv2.
    It will not prevent a non-domain pc from connecting.  You would probably have to configure certificates-only authentication to do that effectively.
  • 5.  RE: VIA vpn - machine authentication
    Posted Mar 20, 2020 08:47 AM
    I'm not sure if cert-only authentication will be supported by DUO, because DUO uses only PAP as an auth method.
    any idea?
  • 6.  RE: VIA vpn - machine authentication
    Posted Mar 23, 2020 09:41 PM
    Well noted !!
    another question here is there a way to have separate "VIA web auth", for instance, let's say 2 FQDNs each will prompt a specific connection profile to the VIA client
    feasible?
