  • 1.  Virtual Controller Upgrade
    Posted Sep 06, 2024 02:39 AM
    i have been trying to upgrade aruba virtual controller "207"  6.5.1.0,
    i have searched for automatic upgrade on the controller to a new version but its giving "received no response from server"
    And manually its requiring 2 URL options " Ursa" & "Vela"
    how can i fix this issue
    thanks!!
  • 2.  RE: Virtual Controller Upgrade
    Posted Sep 06, 2024 07:50 PM
    IAP-207 only requires vela
    Ursa is for AP-303H
  • 3.  RE: Virtual Controller Upgrade
    Posted Sep 09, 2024 03:36 AM
    can i go straight from 6.5.1.0-4.3.1.2_58595 to Vela_8.6.0.25_90367 ?
  • 4.  RE: Virtual Controller Upgrade
    Posted Sep 09, 2024 04:27 AM
    According to the release notes:
    https://www.arubanetworks.com/techdocs/Aruba-Instant-8.x-Books/Release-Notes/86/Aruba-Instant-8.6.0.25-Release-Notes.pdf
    Refer to this section:
    "Upgrade from Instant 6.4.x.x-4.2.x.x to Instant 8.6.0.x
    Before you upgrade an Instant AP running Instant 6.5.4.0 or earlier versions to Instant 8.6.0.x, follow the
    procedures mentioned...."
    Hence; upgrade to the latest 6.5.4.x and then onward.
    As with any upgrade - due diligence, preparation and caution are prudent.
    Notes from experience:
    If the IAP are using VPN-NG tunnels terminated on an AOS /MD/BGW consult the applicable release notes carefully,
    Particularly an AOS command 'iapvpn-backward-compatible' (refer to the AOS CLI Reference guide).
    Mesh is significantly different.
    Shawn Adams
