  • 1.  Visual RF orientation and Beamwidth
    Posted Aug 28, 2013 08:59 PM
    Hello Everyone
    Im doing a simulation in visual RF with AP 175P
    Now im wondering if im doing it properly
    We are selecting omnidirectional antenas a Pair of 5 DB for 2.4ghz and a pair of 10DB for 5ghz.
    In the propierties as its omnidirectional i should put in the orientation 0 and beamwidth 360?  i guess on the gain part i just put the values of the antenas im using....
    Cheers
    Carlos
  • 2.  RE: Visual RF orientation and Beamwidth
    Posted Aug 29, 2013 08:06 PM
    anyone?
  • 3.  RE: Visual RF orientation and Beamwidth
    Posted Sep 02, 2013 08:53 PM
    I'll have someone look into this and get back to you.
  • 4.  RE: Visual RF orientation and Beamwidth
    Posted Sep 03, 2013 12:59 PM
    The beamwidth should definitely be 360.  The orientation could be 0 or anything else.
  • 5.  RE: Visual RF orientation and Beamwidth
    Posted Sep 04, 2013 09:34 AM
    Another question
    if i use a antenna of 180 degreess then the beamwith should be 180
    And what about the orientation ? i guess the orientation should be where to i want to point tha irradiation could be in front or in the back or something like that?
  • 6.  RE: Visual RF orientation and Beamwidth
    Posted Sep 04, 2013 01:16 PM
    If you're using a 180degree patch, it generally has a direction in which it claims to send the beam.
    Set the direction in VisualRF in the same direction you aim the patch.
