  • 1.  VisualRF Plan 7.7
    Posted Jul 05, 2017 05:55 AM
    i have a problem in my visualRF 7.7,i cant use the edit menu its always say that floor editing is locked even though i already unlock the editing menu
    any advice?
  • 2.  RE: VisualRF Plan 7.7
    Posted Jul 05, 2017 06:21 AM
    I would suggest to update AirWave. AiRwave 7.7 is out of support since 1st of July 2015.
    It could be a Browser or Flash issue.
    I haven´t seen any related issue in the last 7.7.x version Release Notes or in the 8.0.3 Release Notes.
    Since 8.x of AirWave we move to HTML5 version of VisualRF, so be aware of supporting Browsers.
  • 3.  RE: VisualRF Plan 7.7
    Posted Jul 05, 2017 06:24 AM
    Sorry, I realized you are using standalone Tool VisualRF.
    You will find Release Notes while clicking on the link below.
    Best would be to donwload latest version which is 8.0_rc1_b496 from support page:
    https://support.arubanetworks.com/DownloadSoftware/tabid/75/DMXModule/510/EntryId/22319/Default.aspx
  • 4.  RE: VisualRF Plan 7.7
    Posted Jul 05, 2017 08:13 PM
    how can i access the support page ?
    its say
    UserWithNoRole
    We identify that you are using Support Portal for the first time.
    *If you are a customer, kindly click here
    to
    Register.
    *If you are a Partner, kindly click here
    to Register.
    *For others, click hereto take a lookat our public content
    is the account different from the community page ?
  • 5.  RE: VisualRF Plan 7.7
    Posted Jul 06, 2017 01:16 AM
    You only have access to that section if you have a valid Support Contract.
  • 6.  RE: VisualRF Plan 7.7
    Posted Jul 06, 2017 05:05 AM
    So how to get the valid contract support sir? Join the member or something
    else?
  • 7.  RE: VisualRF Plan 7.7
    Posted Jul 06, 2017 06:25 AM
    If you dont have access to support, register. Normally it will take four working days to get access.
    Call support to check the status.
    Pavan
  • 8.  RE: VisualRF Plan 7.7
    Posted Jul 07, 2017 03:20 AM
    thanks sir but i have another problem.
    when register new account on the email column its always failed they say
    the domain for the email is not valid even thought
    i fill in with this email account.
    any solution sir?
  • 9.  RE: VisualRF Plan 7.7
    Posted Jul 07, 2017 04:29 AM
    Call support and request for account
    http://www.arubanetworks.com/support-services/contact-support/
    Pavan
