AOS-CX Switch Simulator
VLan and STP configuration
  • 1.  VLan and STP configuration
    Posted May 22, 2023 01:52 PM
    Hi Airheads Team
     I have a 2 6300m core switch and 5 6100 access switch want configuration I designed  ring topology   need help to config  I have also designed  vlans give me the configuration  solution. How to configure static pool in core switch how configure 1 core is redundant
    Also attached plan details  give the solution .thanks
    Vlan's Details
    Sr.No
    Vlan ID
    Vlan Description
    Vlan Name
    Vlan IP/Gateway
    Subnet Mask
    IP  Range
    No of Hosts
    1
    VLAN_10
    Firewall to Switch
    FW-VLAN
    10.10.1.1/27
    255.255.255.224
    10.10.1.1 to 10.10.1.30
    30
    2
    VLAN_11
    Server/DMZ VLAN
    SERVER-VLAN
    10.10.2.1/28
    255.255.255.240
    10.10.2.1 to 1 10.10.1.15
    16
    3
    VLAN_12
    Desktop/Laptop/Printer VLAN
    DESKTOP-VLAN
    10.10.4.1/23
    255.255.254.0
    10.10.4.1 to 10.10.5.254
    512
    4
    VLAN_13
    ICU VLAN
    ICU-VLAN
    10.10.6.1/24
    255.255.255.0
    10.10.6.1 to  10.10.6.254
    254
    5
    VLAN_14
    EDC/POS machine VLAN
    EDC-VLAN
    10.10.7.1/24
    255.255.255.0
    10.10.7.1 to  10.10.7.254
    254
    6
    VLAN_15
    Wifi Access Point VLAN
    ACCESSPOINT-VLAN
    10.10.8.1/24
    255.255.255.0
    10.10.8.1 to  10.10.8.254
    254
    7
    VLAN_16
    Guest User VLAN
    GUEST-VLAN
    10.10.9.1/24
    255.255.255.0
    10.10.9.1 to  10.10.9.254
    254
    8
    VLAN_17
    IOT Devices
    IOT-VLAN
    10.10.10.1/24
    255.255.255.0
    10.10.10.1 to  10.10.10.254
    254
    9
    VLAN_18
    Biometric VLAN
    BIOMETRIC-VLAN
    10.10.11.1/26
    255.255.255.192
    10.10.11.1 to 10.10.11.63
    Attachment(s)
  • 2.  RE: VLan and STP configuration
    Posted May 24, 2023 04:07 AM
    This is the Aruba CX simulator community, so your question is a bit misplaced.
    Your request for help requires more time and resources you can expect from a community like this. Perhaps you could reach out to a local Aruba partner to get help?
    As a starting point you also need to look into how the proposed connections are. The drawing look like you want to connect 10G and 1G interfaces. It will not work, you need to have the same speed on connected interfaces.
    4G total in to your core from access switches look like it may be a bad way to wire it together.
    Arne Opdal
  • 3.  RE: VLan and STP configuration
    Posted May 29, 2023 08:51 AM
    Thank you for pointing out the potential issues with the proposed connections and network design.
    also  i want know how to config DHC_server on 6300m for multiple Vlan's
