Become a Member
Hello! There are some problems with configuring the routing on the HPE A5120 SI. I have Core switch HP Procurve 2920-24G (revision WB.15.11.0003, ROM WB.15.04) with ip routing enabled and several vlan's, and HPE A5120-SI (Software ver. 5.20 Release 1518P05)
What is the IP addressing on the 2920 on VLAN2
What is the IP addressing on the host on the 5120 switchport when that switchport is untagged in VLAN 10
What is the IP addressing on the host on the 5120 switchport when that switchport is untagged in VLAN 2
1. 2920 on VLAN2: 192.168.1.100
2. 192.168.10.0/24, work fine
3. 192.168.1.0/24, does not work
We need to know the IP address, subnet mask and default GW for each.
