Use standalone. I think 8.x doesn't support master-local, but it should support master-backup. The traditional master has been replaced by the Mobility Conductor (MCR or MM)
Original Message:
Sent: Sep 03, 2021 04:17 AM
Subject: VM config for MM
I', trying to install a new VM machine to be used as a MM. I have used ArubaOS_VMC_8.5.0.10_76206.ova but when I'm deploying the VM I cannot see the option to run the VM as a master:
do you know why I cannot see the 'master' option here ?
thank you!
ioanf
