Voice Vlan on Hospitality AP-505H ports (AOS 8.10 - campus)
  • 1.  Voice Vlan on Hospitality AP-505H ports (AOS 8.10 - campus)
    Posted Oct 08, 2024 04:03 PM
    Hello there..
    I'm trying to power up a VOIP phone on one of the AP 505H ports, but not sure how to properly configure the Wired Port profile since there is no way to mark a voice vlan.
    No matter how I configured the port, the phone is stuck at DHCP Discovery Option 125.
    The feed switch port (cisco) is configured with a voice vlan and access vlan. If I plug the phone there, it works, so something is not passing thru.
    I tried Trusted on/off, Forward mode tunnel and bridge, Switchport mode access and tunnel, and setting the access mode vlan to the voice vlan. In fact, if I set the access vlan to the voice vlan and connect another device, it properly gets an IP address. I opened up a case with TAC and got some packet captures but I figured I'm not the only one that's ever done this, right? These are Mitel VOIP phones.
    Any ideas? TIA.
  • 2.  RE: Voice Vlan on Hospitality AP-505H ports (AOS 8.10 - campus)
    Posted Oct 08, 2024 04:10 PM
    Are you expecting the AP to advertise a voice VLAN using LLDP?  Make sure to pass the VLAN as tagged or untagged, depending on what the phone is expecting.
    https://www.arubanetworks.com/techdocs/ArubaOS_8.12.0_Web_Help/Content/arubaos-solutions/voice-video/conf-lldp-med-prof.htm
    Carson Hulcher, ACEX#110
