Become a Member
I am trying to figure out what the difference is between a Trunk Port and a Hybrid port. I am working on a voice vlan configuration and I've seen voice vlans be configured on both trunk types and hybrid types. I will be using PoE Cisco phones so I am assuming I want to go with a trunk port. Can anyone add some clarification as to the advantages of both types?
Hi !
http://h30499.www3.hp.com/t5/LAN-Routing/Trunks-VLANs-Question/m-p/6692234#M1188
So in the case of using VoIP phones, in Cisco world, I am used to using a trunked port. Is it advisable to use a hybrid in Comware world even if the Voice VLAN is tagged?
I usually use trunk port on VOIP configuration ... it works normally. But you should not have problems using hybrid port
