But there are some nuances..
Original Message:
Sent: Aug 04, 2023 09:51 AM
Subject: VOIP Deployment
then you need do a packet capture and verify if the phones are providing the correct lldp information.
if that's not matching your definition then it is no surprise.
Alternatively - you could have a look at "local mac auth" .....
Note: I did some longer time ago verify the device-identity in combination with Aruba-AP - that did work properly
Note2: hope you are using a recent firmware, there might be issues in older versions
Original Message:
Sent: Aug 04, 2023 09:42 AM
The problem with the mac-addres that suddenly wasn't showing anymore was due to the command
aaa port-access lldp-bypass c18
Instead I tried the following
aaa port-access device-identity "AlcatelPhone2" bypass C18
but still doesn't work
Original Message:
Sent: Aug 04, 2023 09:09 AM
Hello
the strange thing is that now I don't see any mac-address when I connect the phone, and it doesn't work.
Original Message:
Sent: Aug 04, 2023 07:31 AM
Hi again,
I think you need to enable globally:
aaa port-access use-lldp-data
and maybe on interface level: poe-lldp-detect
/Jochem
Original Message:
Sent: Aug 04, 2023 07:02 AM
I got it corrected but the configuration seems not to be working.
This is what we did.
The rexpected result is to have a port configured in a way that can automatically set the correct vlan for devices after either 802.1x authentication ( PC ) or device profiling ( Ip Phones )
here is the configuration made on a single port, so far, to test it.
The 802.1x part is already working fine.
Now we're trying to use device profiling to have the IP phones set on the correct vlan
Below the configuration
aaa server-group radius "NPS" host 172.31.200.45
aaa server-group radius "NPS" host 172.31.210.15
aaa authentication web login radius server-group "NPS" local
aaa authentication web enable radius server-group "NPS" local
aaa authentication ssh login radius server-group "NPS" local
aaa authentication ssh enable radius server-group "NPS" local
aaa authentication port-access eap-radius server-group "NPS"
aaa authentication mac-based chap-radius server-group "NPS"
aaa port-access authenticator C18
aaa port-access authenticator C18 client-limit 1
aaa port-access authenticator active
aaa port-access mac-based C18
aaa port-access mac-based C18 unauth-vid 203
aaa port-access C18 auth-order authenticator mac-based
aaa port-access C18 auth-priority authenticator mac-based
aaa port-access lldp-bypass C18
device-identity name "AlcatelPhone"
lldp oui 788102 sub-type 1
exit
device-identity name "AlcatelPhone2"
lldp oui 00809f sub-type 1
exit
device-profile name "IP-Phone"
untagged-vlan 212
cos 5
allow-jumbo-frames
exit
device-profile device-type "AlcatelPhone"
associate "IP-Phone"
enable
exit
device-profile device-type "AlcatelPhone2"
enable
exit
Original Message:
Sent: Aug 02, 2023 04:01 AM
Hi Stefano,
I guess it's just a typo in the document - pls. try "allow-jumbo-frames" with an additional dash.....
you can always verify commands by typing the "?" (or filtered using e.g. "a?" for possible commands starting with an "a")
/Jochem
Original Message:
Sent: Aug 01, 2023 05:25 AM
I'm deploying a VOIP solution using a 5412R ZL2 running version KB.16.11.0010.
Following the documentation found in the Document "VoIP Deployment on ArubaOS-Switch ArubaOS-Switch 16.06"
I followed these steps.
switch(config)# device-identity name "VoIP-Phone"
switch(identity-VoIP-Phone)# lldp oui 0012bb sub-type 1
switch(identity-VoIP-Phone)# exit
Next, create the device profile with settings to be applied to provisioned ports:
switch(config)# device-profile name "Phone-Profile"
switch(device-profile)# tagged-vlan 100
switch(device-profile)# untagged-vlan 110
switch(device-profile)# allow-jumbo frames
The problem is that the "allow-jumbo frames" does not exists.
Has it been removed, I couldn't find an equivalent
The other question is about the following
switch(config)# device-profile device-type "VoIP-Phone"
switch(device-VoIP-Phone)# associate "Phone-Profile"
switch(device-VoIP-Phone)# enable
Can I associate more than one Phone Device type to the "phone-profile" ?
thanks
