Hi.
I am currently using a "tagged voice + untagged data" vlan setup for a voip installation.
This works well apart from the first bootup of the phone (snom 360). The phone at this stage does not have its template indicating that (in my case) vlan 144 is the voice vlan, and that the untagged vlan can be passed through the phone to the data connector on the phone (which plugs into your laptop etc).
So the first time the phone boots, it boots into the untagged vlan, meaning it needs routes into the voice vlan to retrieve its config, it consumes a dhcp address on a scope to which it does not belong etc etc.
Second boot, it has its template, and everything works the way it should.
My question - is there any methods to avoid these "deployment time" problems?
Cisco CDP works well here because it runs at layer 2, meaning the phone can drop into the right vlan at boot time.
I udnerstand there exists another similar protocol LLDP-MED - does anyone know if it will help with my dilemma and potentially have config example.
I also understand that 802.1x may be the better way to do this (better security), but I don't have all the resources I need to implement this yet.
I appreciate any responses!
Cheers,
R.
