Got a question about ipsec shared keys
Our mobility controllers are configured to support L2TP/IPSec connectivity for our remote APs . For a while now. I've been using the OS X / iOS built in VPN client to connect to the Univertsity using this L2TP/IPSec route. At present this means that I'm using the same shared key we configure into all of our remote Access Points.
We're now in a situation where we want to roll out the Aruba VPN setup to a wider audience (e.g. all of IT Services). What I don't want to do is hand out the same shared key we use for our remote APs to every man and his dog.
1). Can we confiure our controllers to support multiple shared keys for ipsec connectivity?
2). If so any conifg examples/docn appreciated.
At this point in time I don't want to look at using VIA as that's just replacing one vn client to install on a machine with another one. I'd rather try and use an operating system supported built in client.
Rgds
Alex
