Comware
  • 1.  VPN instances without MPLS?
    Posted Nov 06, 2012 08:17 PM
    Hi everyone,
    In my 5500-EI IRF stack, i'd like to have a few different routing instances - potentially one for upstream BGP, one for the management networks, and one for the main data centre networks.  Is this possible using the VPN instances available on Comware 5?
    Everything i've found in the documentation suggests that it assumes/requires MPLS transports all through your network, which i don't want - i just want separate instances within the one stack.
    #vpn
  • 2.  RE: VPN instances without MPLS?
    Posted Nov 07, 2012 01:23 AM
    Yeah you could use vpn-instances for that, it does not require MPLS.
  • 3.  RE: VPN instances without MPLS?
    Posted Nov 07, 2012 02:24 AM
    Thanks Fredrik,
    So which parts of the configuration are required in order to set up the VPN instances?  The manuals seem to imply that you must have BGP route descriptors and MPLS.
  • 4.  RE: VPN instances without MPLS?
    Posted Nov 07, 2012 09:44 AM
    Just poked through this: http://h20195.www2.hp.com/v2/GetPDF.aspx/4AA3-7311ENW.pdf dont know if thats the one you've been looking at. But you just need to define the vpn-instances, and give them a route-destinguisher. No MPLS _needed_, allthough vpn-instances is used heavily together with MPLS.
    So something like this:
    ip vpn-instance red
     description Customer red
     route-distinguisher 1:1
    interface GigabitEthernet2/0/1
     description Int to cust red
     ip binding vpn-instance red
  • 5.  RE: VPN instances without MPLS?
    Posted Nov 07, 2012 02:26 PM
     Btw, you can have up to 64 instances on the A5500-EI, up to 1024 on A5500-HI and A5800
