SD-WAN
  • 1.  VPNC - Minimum req for gateway
    Posted Mar 24, 2021 01:03 PM
    Hi.
    I just joined the airheads and work for a aruba partner in Norway.
    What is the minimum requirement for at gateway configured as a VPNC?
    Can the 9004 act as VPNC?
    Cheers,
    Ole Morten Kårbø
    Ole Morten Kårbø
  • 2.  RE: VPNC - Minimum req for gateway
    Posted Mar 24, 2021 05:30 PM
    You can't use 7005/7008 but you will need to look at the limitations on the gateway you are planning to use to determine if it meets your requirements  (IPSec tunnels , throughput, etc..)
    You can use the 9000 series gateways as VPNCs
    Victor Fabian, ACEX#8
    Mobility Architect @ WEI
