SD-WAN
  • 1.  VPNC Route Advertisement Issue
    Posted Oct 04, 2024 05:25 AM
    I have a setup with two VPNCs in a cluster.  The branch 9004 is forming an Internet and LTE tunnel to VPNC2 and the MPLS tunnel to VPNC1.  This is done by the Orchestrator.  The issue is that only VPNC2 is advertising routes from the data center over the Internet and LTE tunnels.  VPNC1 is not advertising any routes except local IP addresses to the VPNC.  In Dynamic Path Selection, I am trying to prefer the MPLS tunnel for traffic to the data center, but since VPNC1 is not advertising the routes, all traffic is flowing over the Internet tunnel.  How do I get VPNC1 to advertise routes via the MPLS tunnel so the preferred traffic pathing works?
    Topology:
    VPNC1:
    OAP Status
    Admin State:         UP
    Oper State:          UP
    Master:              127.0.0.1:24400
    Channel:             CONNECTED
    Serial:              CNP4KLB023
    MAC:                 28:de:65:a5:d4:b3
    Site ID:             28:de:65:a5:d4:b3
    Tunnel If:           tsgw
    Graceful-restart-timer : 86400 seconds
    Channel UP since:    Wed 2024-10-02 23:02:01 IST
    Channel Down count:  11
    Learnt Routes:       5
    Advertised Routes:   2
    Tunnels:             2
    Keepalive sent:      59818
    Keepalive received:  66010
    Keepalive pending:   0
    PCM Gen ID IPv4:     1726627298787033
    Peak Routes IPv4:      5 at Wed 2024-09-18 09:59:50 IST
    Peak Tunnels:          2 at Wed 2024-10-02 11:08:28 IST
     VPNC2:
    OAP Status
    Admin State:         UP
    Oper State:          UP
    Channel:             CONNECTED
    Serial:              CNP4KLB04N
    MAC:                 28:de:65:a5:db:1b
    Site ID:             28:de:65:a5:db:1b
    Tunnel If:           tsgw
    Channel UP since:    Wed 2024-10-02 23:02:04 IST
    Channel Down count:  13
    Learnt Routes:       5
    Advertised Routes:   16
    Tunnels:             9
    Keepalive sent:      59856
    Keepalive received:  66657
    PCM Gen ID IPv4:     1726627298772384
    Peak Tunnels:          10 at Wed 2024-10-02 11:08:28 IST
    The route tables on the VPNCs are exactly the same, with both supposed to redistribute overlay, connected and static.
    Route table on the branch gateway:
    COMMAND=show ip route
    Codes: C - Connected, O - OSPF, IA - OSPF Inter Area, E1 - OSPF External Type 1, R - RIP
           E2 - OSPF External Type 2, N1 - OSPF NSSA External Type 1, N2 - OSPF NSSA External Type 2
           B I - BGP Interior, B E - BGP Exterior, S - Static
           U - BGW Peer Uplink, M - Management, Ru - Route Usable, * - Candidate Default
           V - RAPNG VPN/Branch, I - Crypto-Cfgset, N - Not Redistributed, Bc - Cloud Overlay Protocol
    S*    0.0.0.0/0  [50/10] via 10.68.152.181
                     [50/10] via 192.168.1.1
    Bc    172.31.0.0/23  [90/20] ipsec map data-vpnc-28:de:65:a5:d4:b3-lte_lte
                         [90/20] ipsec map data-vpnc-28:de:65:a5:d4:b3-boyle_inet_inet
    Bc    192.168.0.0/16  [90/20] ipsec map data-vpnc-28:de:65:a5:d4:b3-lte_lte
    I     10.10.0.2/32  [70/10] ipsec map data-vpnc-28:de:65:a5:d4:b3-mpls_mpls
    Bc    10.254.76.19/32  [90/10] ipsec map data-vpnc-28:de:65:a5:d4:b3-mpls_mpls
    Bc    10.254.76.3/32  [90/20] ipsec map data-vpnc-28:de:65:a5:d4:b3-lte_lte
    Bc    172.29.5.0/24  [90/20] ipsec map data-vpnc-28:de:65:a5:d4:b3-lte_lte
    Bc    10.133.0.0/16  [90/20] ipsec map data-vpnc-28:de:65:a5:d4:b3-lte_lte
    C     10.10.1.3/32 is directly connected, VLAN4000
    Bc    172.31.33.0/24  [90/20] ipsec map data-vpnc-28:de:65:a5:d4:b3-lte_lte
    C     192.168.1.0/24 is directly connected, VLAN4094
    Bc    192.168.5.0/24  [90/20] ipsec map data-vpnc-28:de:65:a5:d4:b3-lte_lte
    Bc    172.33.250.0/24  [90/10] ipsec map data-vpnc-28:de:65:a5:d4:b3-mpls_mpls
    Bc    10.0.0.0/8  [90/20] ipsec map data-vpnc-28:de:65:a5:d4:b3-lte_lte
    I     10.254.76.1/32  [70/10] ipsec map data-vpnc-28:de:65:a5:d4:b3-mpls_mpls
    Bc    172.16.250.0/24  [90/10] ipsec map data-vpnc-28:de:65:a5:d4:b3-mpls_mpls
    I     10.10.0.1/32  [70/10] ipsec map data-vpnc-28:de:65:a5:d4:b3-lte_lte
                        [70/10] ipsec map data-vpnc-28:de:65:a5:d4:b3-boyle_inet_inet
    Bc    10.254.76.8/29  [90/20] ipsec map data-vpnc-28:de:65:a5:d4:b3-lte_lte
    S     192.168.214.38/32  [50/10] via 10.68.152.181
    C     172.33.85.1/32 is directly connected, VLAN1
    S     192.168.208.38/32  [50/10] via 10.68.152.181
    C     10.133.85.0/29 is directly connected, VLAN4093
    C     172.33.85.0/24 is directly connected, VLAN1
    Bc    10.254.76.11/32  [90/20] ipsec map data-vpnc-28:de:65:a5:d4:b3-lte_lte
    Bc    172.16.0.0/12  [90/20] ipsec map data-vpnc-28:de:65:a5:d4:b3-lte_lte
    C     172.16.85.0/24 is directly connected, VLAN2
    I     185.50.100.11/32  [70/10] ipsec map data-vpnc-28:de:65:a5:d4:b3-lte_lte
    Bc    10.254.76.16/29  [90/10] ipsec map data-vpnc-28:de:65:a5:d4:b3-mpls_mpls
    Bc    10.254.76.0/29  [90/20] ipsec map data-vpnc-28:de:65:a5:d4:b3-lte_lte
    Bc    172.33.5.0/24  [90/20] ipsec map data-vpnc-28:de:65:a5:d4:b3-lte_lte
    Bc    172.33.1.0/24  [90/20] ipsec map data-vpnc-28:de:65:a5:d4:b3-lte_lte
    Bc    172.33.2.0/24  [90/20] ipsec map data-vpnc-28:de:65:a5:d4:b3-lte_lte
    Bc    172.33.3.0/24  [90/20] ipsec map data-vpnc-28:de:65:a5:d4:b3-lte_lte
    C     10.68.152.180/30 is directly connected, Loopback
    === Troubleshooting session completed ===
  • 2.  RE: VPNC Route Advertisement Issue
    Posted 7 days ago
    Edited by Oliver Wehrli 7 days ago
    In case this is still an issue that needs a bit more data:
    • How do VPNC1 and VPNC2 learn these routes in the first place?
    • What does the routing table look like on both VPNCs?
    • Have you configured Overlay Route redistribution identically on both VPNC?
    It's worth mentioning that there is a detailed TechNote on how ORO propagates routes and what the prerequisites/logic is: https://www.arubanetworks.com/techdocs/central/sd-branch-ref-docs/sd-branch-orchestrator.pdf
    I work for Aruba. Any opinions expressed here are solely my own and not do not represent that of Hewlett Packard Enterprise or Aruba.
