Comware
  • 1.  VRF on 5700 => no joy
    Posted Oct 17, 2016 02:55 PM
    In the final stages of a network upgrade in a K12 school.
    All new switches in place, with an IRF stack of 5700 at the center. These 5700s have BAGGs to individual HP 2920s that are placed around the school campus.
    The previous network was using a 5412zl for routing, and our goal is to retire this switch (single point of failure compared with IRF stack )
    We have 27 VLAN interfaces, so we are hopefully not hitting the limit of 32 on the 5700s.
    We created two VRFs
    ip vpn-instance vpn10001
    route-distinguisher 10001:1
    vpn-target 65001:10001 import-extcommunity
    vpn-target 65001:10001 export-extcommunity
    ip vpn-instance vpn10002
    route-distinguisher 10002:1
    vpn-target 65001:10002 import-extcommunity
    vpn-target 65001:10002 export-extcommunity
    The second VRF is for guest internet access, and it is the only VLAN interface bound to the VRF
    interface Vlan-interface190
    description VLAN0190
    ip binding vpn-instance vpn10002
    ip address 10.2.0.1 255.255.252.0
    The first VRF is for the rest of the production network traffic, and each of the 26 remaining VLAN interfaces was bound to it using commands like:
    interface Vlan-interface185
    description VLAN0185
    ip binding vpn-instance vpn10001
    ip address 10.1.185.1 255.255.255.0
    dhcp select relay
    dhcp relay server-address 10.1.100.32
    dhcp relay server-address 10.1.100.33
    default routes were added to each VRF
    ip route-static vpn-instance vpn10001 0.0.0.0 0 10.1.99.2
    ip route-static vpn-instance vpn10002 0.0.0.0 0 10.2.0.2
    At this point we literally went to every building, got on each individual VLAN with multiple clients, and verified routing / Internet access was working and it was.
    Then came the following morning...
    Symptoms included some clients working fine, while others could not ping their gateway IP. We were able to find two clients on the same VLAN on the same 2920 and confirm that one could ping the GW, while the other could not, yet they could ping each other. At first we looked at spanning tree ( all switches configured for MSTP ) and could find no ports in abnormal conditions or any signs of any recent STP events.
    We ended up removing all the VLAN Interface entries and moved routing back to the 5412zl, and all is working now.
    I did NOT get a copy of the config running on the 5700s at the time of the incident, but what I do have is the current running config, and a text file that i created for the purpose of "moving" the routing functionality to the 5700 switches.
    Note -> we did leave the smaller VRF on the 5700 and it is working fine for guest internet ( we never had any issues with this VRF during the incident ).
    Anyone have any ideas how to troubleshoot this scenario?
    The procedure used to move routing was simple. First we downed the interface to the 5412zl, then i pasted the following into the 5700 config:
    interface Vlan-interface40
    description VLAN0040
    ip address 10.1.40.1 255.255.255.0
    dhcp select relay
    interface Vlan-interface099
    description VLAN0099
    ip address 10.1.99.1 255.255.255.0
    interface Vlan-interface100
    description VLAN0100
    ip address 10.1.100.1 255.255.255.0
    dhcp select relay
    interface Vlan-interface111
    description VLAN0111
    ip address 10.1.111.1 255.255.255.0
    dhcp select relay
    interface Vlan-interface110
    description VLAN0110
    ip address 10.1.110.1 255.255.255.0
    dhcp select relay
    interface Vlan-interface112
    description VLAN0112
    ip address 10.1.112.1 255.255.255.0
    dhcp select relay
    interface Vlan-interface115
    description VLAN0115
    ip address 10.1.115.1 255.255.255.0
    dhcp select relay
    interface Vlan-interface120
    description VLAN0120
    ip address 10.1.120.1 255.255.252.0
    dhcp select relay
    interface Vlan-interface124
    description VLAN0124
    ip address 10.1.124.1 255.255.252.0
    dhcp select relay
    interface Vlan-interface129
    description VLAN0129
    ip address 10.1.129.1 255.255.255.0
    dhcp select relay
    interface Vlan-interface132
    description VLAN0132
    ip address 10.1.132.1 255.255.252.0
    dhcp select relay
    interface Vlan-interface136
    description VLAN0136
    ip address 10.1.136.1 255.255.252.0
    dhcp select relay
    interface Vlan-interface140
    description VLAN0140
    ip address 10.1.140.1 255.255.254.0
    dhcp select relay
    interface Vlan-interface150
    description VLAN0150
    ip address 10.1.150.1 255.255.254.0
    dhcp select relay
    interface Vlan-interface152
    description VLAN0152
    ip address 10.1.152.1 255.255.254.0
    dhcp select relay
    interface Vlan-interface160
    description VLAN0160
    ip address 10.1.160.1 255.255.254.0
    dhcp select relay
    interface Vlan-interface162
    description VLAN0162
    ip address 10.1.162.1 255.255.254.0
    dhcp select relay
    interface Vlan-interface170
    description VLAN0170
    ip address 10.1.170.1 255.255.254.0
    dhcp select relay
    interface Vlan-interface172
    description VLAN0172
    ip address 10.1.172.1 255.255.254.0
    dhcp select relay
    interface Vlan-interface180
    description VLAN0180
    ip address 10.1.180.1 255.255.254.0
    dhcp select relay
    interface Vlan-interface182
    description VLAN0182
    ip address 10.1.182.1 255.255.254.0
    dhcp select relay
    dhcp select relay
    interface Vlan-interface200
    description VLAN0200
    ip address 10.1.200.1 255.255.254.0
    dhcp select relay
    interface Vlan-interface202
    description VLAN0202
    ip address 10.1.202.1 255.255.254.0
    dhcp select relay
    interface Vlan-interface204
    description VLAN0204
    ip address 10.1.204.1 255.255.252.0
    dhcp select relay
    interface Vlan-interface208
    description VLAN0208
    ip address 10.1.208.1 255.255.252.0
    dhcp select relay
    bgp 65001
    router-id 192.168.21.2
    address-family ipv4 unicast
    import-route direct
    import-route direct
    import-route direct
    ntp-service source Vlan-interface115
  • 2.  RE: VRF on 5700 => no joy
    Posted Oct 17, 2016 03:05 PM
    Meant to include the 5700s are running this version of Comware: Software Version 7.1.045, Release 2422P01
