you can look for Overlay Tunnel Orchestrator in the Orchestrator Tech Note.
Original Message:
Sent: Dec 02, 2024 07:41 AM
Subject: vrf segments sd-branch
Does anyone have a good deployment guide how to setup vrf segments for SD-Branch? On each spoke site I have 3 networks, VLAN 10, VLAN 20 and VLAN 30 that I want separated. On the VPNC I have one VLAN 100 that is connected to my core router using ebgp. On the core router I want to import routes tagged with vrf targets for VLAN10, VLAN20 and VLAN30 into different vrf´s. Is this possible to setup with SD-Branch?
When looking in Aruba Central it seems that on the VPNC I also need the same VLANs mapped to the network segments on the spoke sites.
