VRRP configuration not in MM GUI!!
  • 1.  VRRP configuration not in MM GUI!!
    Posted Jul 22, 2019 10:45 AM
    We currently have two 7205 controllres in a cluster managed by mobility master.
    I noticed that the VRRP for one of the vlans is configured on each of the controllers-but it is not in Mobility Master under none of the trees.
    Clustering information for the two controllers is shown in MM GUI
    but no vrrp information
    Everything seems to be working properly-we have even had failover testing of a local controller..and that seemed to work out fine.
    config in the local controller or am I confusing VRRP and clustering
    (WLANCTRL01)#
    lc-cluster group-profile "SD_VRRP"
        controller 10.5.198.21 priority 128 mcast-vlan 0 vrrp-ip 0.0.0.0 vrrp-vlan 0 group 2
        controller 10.5.198.22 priority 128 mcast-vlan 0 vrrp-ip 0.0.0.0 vrrp-vlan 0 group 2
    (WLANCTRL02) #
    (WLANCTRL01)#
    vrrp 198
        priority 255
        ip address 10.5.198.20
        description "SD_VRRP"
        vlan 198
        no shutdown
    (WLANCTRL02)#
    vrrp 198
        vlan 198
        no shutdown
    (WLANCTRL01) *#show vrrp summary
    Number of existing VRRP IPv4 instances :    1
    Number of existing VRRP IPv6 instances :    0
    (WLANCTRL01) #show vrrp
    Virtual Router 198:
        Description SD_VRRP
        Admin State UP, VR State MASTER
        IP Address 10.5.198.20, MAC Address 00:00:5e:00:06:62, vlan 198
        Priority 255, Advertisement 1 sec, Preemption Disable Delay 0
        Auth type NONE ********
        tracking is not enabled
    (NY-WLANCTRL01-7205) *#
    (WLANCTRL02) *#show vrrp summary
    (WLANCTRL02) ^#show vrrp
    Virtual Router 198:
        Description SD_VRRP
        Admin State UP, VR State BACKUP
        Priority 100, Advertisement 1 sec, Preemption Disable Delay 0
  • 2.  RE: VRRP configuration not in MM GUI!!
    Posted Jul 22, 2019 10:56 AM
    Please open a TAC case, another community member found this, and while I haven't seen it in my labs, it warrants investigation
