  • 1.  VRRP Debug logging
    Posted Jan 09, 2013 06:32 AM
    Does anybody know if the vrrpd process has been intentionally removed from the debugging process options?
    The CLI guide for version 5.0 says the following command can be used:
    logging level debugging network process vrrpd
    but when I try and use this on an Aruba 6000 SC-2 running ArubaOS 5.0.4.10 the vrrpd option is not there!
    Anybody have any ideas?
    I have a customer with a vrrp issue and we would like to enable debugging for the vrrp traffic.
  • 2.  RE: VRRP Debug logging
    Posted Jan 09, 2013 10:32 AM
    David,
    If you turn on network debugging, you should see the VRRP information there.
