Comware
  • 1.  VRRP error
    Posted May 25, 2010 01:12 PM
    Hi, could someone see whats wrong with my vrrp setup, I got two 5406 with VRRP and mstp.
    This is setup looks same on all vlans, this is example from vlan31 and vlan 32 on both routers (46router1 and 46router2)
    Thanks, Magnus
    46router1
    vlan 31
    vrrp vrid 1
    owner
    virtual-ip-address 10.46.31.254 255.255.255.0
    priority 255
    enable
    exit
    exit
    vlan 32
    vrrp vrid 1
    backup
    virtual-ip-address 10.46.32.254 255.255.255.0
    enable
    exit
    exit
    46router1# show vrrp vlan 31 config
    VRRP Virtual Router Configuration Information
    Vlan ID : 31
    Virtual Router ID : 1
    Administrative Status [Disabled] : Enabled
    Mode [Uninitialized] : Owner
    Priority [100] : 255
    Advertisement Interval [1] : 1
    Preempt Mode [True] : True
    Preempt Delay Time [0] : 0
    Respond To Virtual IP Ping Requests [Yes] : Yes
    Primary IP Address : Lowest
    IP Address Subnet Mask
    46router1#
    46router1# show vrrp vlan 31 statistics
    VRRP Virtual Router Statistics Information
    Vlan ID : 31
    State : Master
    Up Time : 106 mins
    Virtual MAC Address : 00005e-000101
    Master's IP Address : 10.46.31.254
    Associated IP Addr Count : 1 Near Failovers : 1
    Advertise Pkts Rx : 1 Become Master : 1
    Zero Priority Rx : 0 Zero Priority Tx : 0
    Bad Length Pkts : 0 Bad Type Pkts : 0
    Mismatched Interval Pkts : 0 Mismatched Addr List Pkts : 0
    Mismatched IP TTL Pkts : 0 Mismatched Auth Type Pkts : 0
    46router1#
    46router2
    vlan 31
    vrrp vrid 1
    backup
    enable
    exit
    exit
    vlan 32
    vrrp vrid 1
    owner
    priority 255
    enable
    exit
    exit
    46router2# show vrrp vlan 31 config
    Vlan ID : 31
    Mode [Uninitialized] : Backup
    Priority [100] : 100
    46router2#
    46router2# show vrrp vlan 31 statistics
    <CR>
    Vlan ID : 31
    State : Backup
    Up Time : 98 mins
    Associated IP Addr Count : 1 Near Failovers : 2
    Advertise Pkts Rx : 5895 Become Master : 0
    46router2#
    </CR>
  • 2.  RE: VRRP error
    Posted May 26, 2010 04:27 AM
    My fault, everything seems to work, but vrrp ip is not possible to ping when owned by backup vrrp.
    Magnus
  • 3.  RE: VRRP error
    Posted May 26, 2010 08:00 AM
    i don't know exactly but i think with K.14.51 you can enable the virtual ip to be pingable.
    (#router vrrp virtual-ip-ing).
    hth
    alex
