VRRP - Master/Backup master setup
  • 1.  VRRP - Master/Backup master setup
    Posted Mar 26, 2015 01:58 PM
    We currently have a 7210 as our master controller with no AP's terminating on it. We're putting in another 7210 in another building and configuring it to be a backup master. I'd like to setup VRRP between the both and I'm wondering if it is best practice to build a physical link between the two and only allow VRRP traffic over it or should I used my existing uplink (trunk) and just add the VLAN I'm creating for the VRRP instance?
    #7210
  • 2.  RE: VRRP - Master/Backup master setup
    Posted Mar 26, 2015 07:59 PM
    The latter.
  • 3.  RE: VRRP - Master/Backup master setup
    Posted Mar 27, 2015 02:25 AM
    HI,
    Here we need to consider only distance and reachablity. If their iplink is L2 ( Not routed)  then you can use the uplink to bring up VRRP, otherwise create a separate link.
    Here important thing is VRRP heart beat, Mater redundancy rely on VRRP, as long as the VRRP is stable Master redundancy will be stable :)
    Please feel free if you need some more clarity on this.
