  • 1.  VSC egress clients on same AP can't communicate?
    Posted Sep 03, 2012 08:47 AM
    Hoping someone can point me in the right direction here...
    VSC Profile...
    * central authentication (RADIUS), no access control
    * Egress is dynamic VLAN ... all works great
    * Clients on different ap's (same egress vlan) can communicate OK
    However, clients associated with the same access point (on same vlan) can't seem to talk to one another ?
  • 2.  RE: VSC egress clients on same AP can't communicate?
    Posted Sep 03, 2012 09:47 AM
    If you're running the latest, 5.7.0.3, it's a new bug that is apparently being worked on. In the meantime, the workaround is to set the QoS for the affected VSC's to normal priority. There are several threads here (mostly mine) since I discovered the problem a few months ago, and this fix worked.
    Please report back if that works for you, too.
  • 3.  RE: VSC egress clients on same AP can't communicate?
    Posted Sep 03, 2012 11:33 PM
    I set QoS on that VSC to 'Disabled' .. no improvement
    We're running firmware 5.5.3.0-01-10326
    More details...
    Controller: MSM765zl (Team of 2)
    APs: MSM422 and E-MSM460
    VSC Config...
    Controller Authentication: YES
    Controller Access Control: NO
    VSC Ingress: SSID
    Broadcast Filtering: YES    (have tried 'NO')
    Allow traffic between: 802.1X   (have tried 'All')
    QoS: Disabled   (have tried 'Diffserv' and 'VSC Normal')
    Mobility: NO
    Fast Roaming: YES
    Security Filters: NO
    IP Filter: NO
    MAC Filter: NO
