Wired Intelligent Edge
  • 1.  VSX Stack to firewall
    Posted Feb 25, 2021 09:17 AM
    Hi guys,
    I want to configure an aruba VSX Stack as cores-switches. The access-switches should be connected via MLAG to the VSX Stack and therefore I want to use the active gateway configuration for routing.
    Now I want to connect the VSX Stack to our Firewall-HA.
    What is the best way to do this, MLAG to both Firewalls?
    Chris
  • 2.  RE: VSX Stack to firewall
    Posted Feb 25, 2021 10:29 AM
    Edited by parnassus Feb 25, 2021 10:35 AM
    Hi Chris,
    "What is the best way to do this, MLAG to both Firewalls?"
    before answering that question let me instead to highlight an aspect of your scenario: can your Cluster of Firewalls be seen as a single (unique) logical entity from the VSX point of view? I mean...generally an Firewall HA solution (Active/Active or Active/Passive, it doesn't matter) is made of two standalone units interconnected with an heartbeat link...and this pair of Firewall units generally can't be seen as a single logical entity (think about: can you freely terminate/distribute link aggregation's members originating on the VSX or on a singel standalone Switch to both the HA Cluster's members concurrently?).
    Davide Poletto
  • 3.  RE: VSX Stack to firewall
    Posted Feb 25, 2021 10:48 AM
    Hi Davide,
    thanks for your quick response.
    Our firewalls are working in an active-passive scenario and they are interconnected over a heartbeat-link.
    Each firewall is a standalone unit.
    So in this scenario, I could configure MLAG on the VSX-Stack to both firewalls?
    Regards
    Chris vBargen
  • 4.  RE: VSX Stack to firewall
    Posted Feb 25, 2021 11:49 AM
    Edited by parnassus Feb 25, 2021 06:35 PM
    Hi Chris,
    "So in this scenario, I could configure MLAG on the VSX-Stack to both firewalls?"
    No.
    You can configure a LAG on Firewall 1: links of this Firewall LAG would terminate on both VSX Members (distributed on VSX node 1 and on VSX node 2), this approach would imply that on the VSX side you need to setup a VSX LAG - call it lag1 (what you call an MCLAG or Multi-Chassis LAG) - and links of this VSX LAG (links originating on VSX 1 and VSX 2)  will end on (and only on) Firewall 1 unit.
    You can configure another LAG on Firewall2: links of this Firewall LAG would terminate on both the VSX Members (distributed on VSX node 1 and on VSX node 2), this approach would imply that on the VSX side you need to setup a VSX LAG - call it lag2 (what you call an MCLAG or Multi-Chassis LAG) - and links of this VSX LAG (links originating on VSX 1 and VSX 2) will end on (and only on) Firewall 2 unit.
    The point is that VSX acts as a single logical unit from peers perspective BUT your Firewall Cluster doesn't so you need to consider each of your Firewalls as a (sort of) separate switch against which the VSX could separately terminate its VSX LAGs' links (VSX lag1 links originating on VSX node 1 and on VSX node 2 go to Firewall 1 lag "n", VSX lag2 links originating on VSX node 1 and on VSX node 2 go to Firewall 2 lag "m").
    The viceversa thus is not valid: you can't have a VSX LAG originating from the VSX members and going to with some links on Firewall 1 and with some others on Firewall 2 exactly as you can't probably setup on your Firewalls a LAG stretched across both Firewalls (a sort of Multi-Chassis de-facto...but for Firewalls) that terminates its links against the VSX Cluster (or against any other standalone Switch, as example).
    Davide Poletto
  • 5.  RE: VSX Stack to firewall
    Posted Feb 26, 2021 04:38 AM
    It may help:
    https://support.hpe.com/hpsc/doc/public/display?docId=a00094242en_us
    p104 Fig.2
    Vincent Giles
