The APs have an internal down tilt omnidirectional array and are made to be mounted on the ceiling. The 90-degree mounts allow you to maintain that orientation if the ceiling is not available for mounting. Most of the coverage extends out and away horizontally. Of course any adjustments will change the propagation, but i wouldn't expect to much of a change.
Dustin Burns
ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
Original Message:
Sent: Oct 16, 2024 07:24 AM
Subject: Wall mounted APs
We have a situation where we have to mount the AP to the wall with an 90 Degree Bracket.
The Question raised was: isn't it bestter to mount the AP at 45 degrees to use more of the Antenna coverage?
