Wired Intelligent Edge
We can not log on to an HP ProCurve Switch 2510G-24 (J9279A) using web browsers.
  • 1.  We can not log on to an HP ProCurve Switch 2510G-24 (J9279A) using web browsers.
    Posted Oct 26, 2018 06:48 AM
    I am a teacher at a high school and teaches in networking.
    We have a problem.
    We have tried to further configure IP with the help of CLI, but without success.
    Do you have any idea what we are doing wrong?
  • 2.  RE: We can not log on to an HP ProCurve Switch 2510G-24 (J9279A) using web browsers.
    Posted Oct 27, 2018 03:28 AM
    I suspect you want to manually assign - initially using Serial Console connection to access the Switch's CLI - an IP Address to always present Switch's Default VLAN (which is generally set to VLAN Id 1 in a factory defaulted Switch configuration) so you can then access the Default's VLAN IP interface addess via HTTP (Web Management)/SSH. Is it true?
