Hi Guys,
We were only trying to connect an Aruba controller to the Aruba core switch(2930F)? what could have cause a loop? ?
Aruba Core switch is connected to a number of cisco access switches via LACP.
Aruba controller is also connected to Aruba coreswitch using a single LAN cable.
Access switch ports are both configured in interfaces of Aruba Controller and Core switch where the controller is connected.
Loop protect is enabled on switchport where the Aruba Controller is connected to the core switch.
Attach is the core switch configuration. Really appreciate if you can point out the root cause and if added switch configs are needed to prevent this issue from happening again.
G
