Developer
  • 1.  Webhook Alerts - field cid
    Posted Oct 26, 2024 07:18 PM
    I've been monitoring alerts using webhook, while the JSON output of most of the alerts match the examples documented on the developer pages; https://developer.arubanetworks.com/hpe-aruba-networking-central/docs/ap-alerts#span-stylecolororangeap-tunnel-downspan
    Other JSON responses include an additional field for 'cid', for example;
      "id": "AZLFUYdYPY4FcW3aO3TZ",
      "cid": "fxxxxxxx1ab7df11ed8bf2e23280cxxxxxx",
      "nid": 1257,
      "alert_type": "AP_TUNNEL_DOWN",
      "setting_id": "2cea0de370d64cfsxxxxx4a808c099fb-1257",
      "device_id": "XXXXXXXXX",
      "description": {
        "text": "AP tunnel vpn_tun_default_0 from 0.0.0.0 to 0.0.0.0 is DOWN on device XXX-XX73-AP01 with serial XXXXXXXXX at 2024-10-25 20:15:07 UTC. Reason: RC_ERROR_IKE_XAUTH_AUTHORIZATION_FAILED",
        "format": "html"
      "state": "Close",
      "severity": "Major",
      "operation": "update",
      "timestamp": 1729976104,
      "details": {
        "src_ip": "0.0.0.0",
        "dst_ip": "0.0.0.0",
        "alias_map_name": "vpn_tun_default_0",
        "name": "XXX-XX73-AP01",
        "reason": "RC_ERROR_IKE_XAUTH_AUTHORIZATION_FAILED",
        "serial": "XXXXXXXXX",
        "group": "2",
        "labels": ["79"],
        "rule_number": "0",
        "time": "2024-10-25 20:15:07 UTC"
      "webhook": "xxxxx5c28-2c91-4f05-b53b-xxxxxxxx",
      "cluster_hostname": "xxxxxxx.central.arubanetworks.com"
    After a bit of digging I've that the CID field matches the Aruba Central's Customer ID, i'm surprised that all of the alerts don't show the CID
    I've configured and applied the webhook at the MSP level, so i'm receive alerts from all subordinate customer accounts, but the cid only appears on a few alerts.
    Can anyone point me to the documentation for the 'cid' field?
    Thanks in advance,
    Mike.
  • 2.  RE: Webhook Alerts - field cid
    Posted Oct 27, 2024 10:20 AM
    Hi Mike,
    You need to ask your SE or TAC...
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
