Cloud Managed Networks
  • 1.  Webhooks - some alerts do not send State Close
    Posted Jun 07, 2021 10:42 AM
    I've recently setup a webhook with an alerting platform which works fine.
    However, some alerts in Central do not send a "state: Close" when the alert becomes clear.
    An example is "AP Disconnected" or "Aggregate Device Disconnections".
    One alert that does send a "State: Close" is Switch Disconnected.
    Why is this the case?
    Automation is critical and this would seem like a no brainer..
    Thanks in advance for any comments, updates on when it might be available or information to the contrary...
    Rory
  • 2.  RE: Webhooks - some alerts do not send State Close
    Posted Aug 19, 2021 07:41 PM
    did you get this sorted?
  • 3.  RE: Webhooks - some alerts do not send State Close
    Posted Aug 25, 2021 06:32 AM
    I think, need to open an issue on TAC...
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
  • 4.  RE: Webhooks - some alerts do not send State Close
    Posted Aug 26, 2021 05:48 AM
    What's the point? I need to open a new one? why?
