  • 1.  What AP model to choose for air monitors?
    Posted Sep 28, 2018 07:44 PM
    Hi guys,
    I have to implement a wireless network with WIPS functionality, and because I am new in WIPS I doubt about what model of AP I would have to use.
    I am going with IAP-315 for APs in access mode, and I will install some APs in air monitor mode. I think I can go with IAP-305 or IAP-303 for air monitors, so they are cheaper. But why not IAP-207? I don't need an AP wave 2 for WIPS either, do I?
    What are your recommendations?
    Thanks in advance,
    Julián
  • 2.  RE: What AP model to choose for air monitors?
    Posted Sep 28, 2018 11:26 PM
    IAP-305 should be fine.  I have never personally used the AP-207 as an air monitor.
    More detailed information about what you should look out for here:  https://www.arubanetworks.com/assets/tg/TG_WIP.pdf
  • 3.  RE: What AP model to choose for air monitors?
    Posted Sep 29, 2018 04:29 PM
    Ok, thanks for the recommendation and the link.
    Julián
  • 4.  RE: What AP model to choose for air monitors?
    Posted Oct 01, 2018 11:06 AM
    Hi Colin,
    One more thing. What do you think about the new AP-303 as an air monitor? I have seen and the price is around the half of the AP-305.
    Julián
  • 5.  RE: What AP model to choose for air monitors?
    Posted Oct 01, 2018 11:13 AM
    What version of AOS is the customer running? The AP-303 requires AOS 8.3.
  • 6.  RE: What AP model to choose for air monitors?
    Posted Oct 01, 2018 11:18 AM
    Hi Charlie,
    I know it, client is running ArubaOS 6.5.x, but for its renewal we are proposing the Instant solution, so there is no problem with that.
    Julián
