Hi guys,
Our 3200XM is with high memory comsuption and there is a proccess that is calling my attention.
What is the fpapps process?
show cpuload current | include fpapps
1672 root 17 0 188m 137m 5192 S 0 20.3 0:00.13 fpapps
1681 root 16 0 188m 137m 5192 S 0 20.3 0:03.41 fpapps
1682 root 15 0 188m 137m 5192 S 0 20.3 215:28.62 fpapps
1900 root 17 0 188m 137m 5192 S 0 20.3 0:00.00 fpapps
2026 root 16 0 188m 137m 5192 S 0 20.3 423:10.80 fpapps
2119 root 16 0 188m 137m 5192 S 0 20.3 0:00.72 fpapps
2120 root 15 0 188m 137m 5192 S 0 20.3 1:11.14 fpapps
2121 root 16 0 188m 137m 5192 S 0 20.3 55:45.23 fpapps
2129 root 16 0 188m 137m 5192 S 0 20.3 0:00.01 fpapps
2156 root 16 0 188m 137m 5192 S 0 20.3 0:17.61 fpapps
2157 root 16 0 188m 137m 5192 S 0 20.3 0:07.42 fpapps
2159 root 16 0 188m 137m 5192 S 0 20.3 0:00.69 fpapps
2170 root 16 0 188m 137m 5192 S 0 20.3 0:16.85 fpapps
2171 root 16 0 188m 137m 5192 S 0 20.3 0:18.29 fpapps
2172 root 15 0 188m 137m 5192 S 0 20.3 0:06.69 fpapps
2173 root 17 0 188m 137m 5192 S 0 20.3 0:00.00 fpapps
2174 root 16 0 188m 137m 5192 S 0 20.3 0:00.15 fpapps
2175 root 17 0 188m 137m 5192 S 0 20.3 0:00.00 fpapps
2353 root 16 0 188m 137m 5192 S 0 20.3 0:56.91 fpapps
2354 root 16 0 188m 137m 5192 S 0 20.3 0:00.02 fpapps
2419 root 15 0 188m 137m 5192 S 0 20.3 748:15.83 fpapps
And what is causing this log?
Jul 2 10:23:23 fpapps[1682]: PAPI_Send: sendto DHCP Server failed: Connection refused Message Code 7007 Sequence Num is 19292
Jul 2 10:23:23 fpapps[1682]: PAPI_Send: sendto DHCP Server failed: Connection refused Message Code 7007 Sequence Num is 19304
Jul 2 10:23:26 fpapps[1682]: PAPI_Send: sendto DHCP Server failed: Connection refused Message Code 7007 Sequence Num is 19280
Jul 2 10:23:26 fpapps[1682]: PAPI_Send: sendto DHCP Server failed: Connection refused Message Code 7007 Sequence Num is 19292
Jul 2 10:23:26 fpapps[1682]: PAPI_Send: sendto DHCP Server failed: Connection refused Message Code 7007 Sequence Num is 19304
Jul 2 10:23:26 fpapps[1682]: PAPI_Send: sendto DHCP Server failed: Connection refused Message Code 7007 Sequence Num is 19316
Cheers,
Thiago Ramos Fanfoni
