what means Valid and Protected SSIDs ( WIPS )
This thread has been viewed 28 times
  • 1.  what means Valid and Protected SSIDs ( WIPS )
    Posted Apr 10, 2018 05:16 AM
    hello
    we have ssid = ssid 1,2,3,4
    we want allow ssid = ssid 1,2,3
    we want block ssid = ssid 4
    so i configured IDS General profile and IDS Unauthorized Device profile .
    i insert ssid 1,2,3 in Valid and Protected SSIDs before running wips ap
    i checked my device. but all wifi bloked.
    i dont understand this situation.
    anyone help me please...IDS General ProfileIDS General ProfileIDS Unauthorized Device 1IDS Unauthorized Device 1IDS Unauthorized Device 2IDS Unauthorized Device 2IDS Unauthorized Device 3IDS Unauthorized Device 3
  • 2.  RE: what means Valid and Protected SSIDs ( WIPS )
    Posted Apr 10, 2018 08:00 AM
    Uncheck  "Protect Misconfigured APs"
    What kinds of clients are you trying to block from those SSIDs?
  • 3.  RE: what means Valid and Protected SSIDs ( WIPS )
    Posted Apr 11, 2018 12:31 AM
    thanks for Reply
    I want all client block ( Laptop , mobile ,wireless etc...) to connect trying ssid 4
    and i test Uncheck  "Protect Misconfigured APs"
    but i blocked all ssid .....
    what can i do ?
  • 4.  RE: what means Valid and Protected SSIDs ( WIPS )
    Posted Apr 11, 2018 07:27 AM
    Do you want to turn off SSID 4, then?
  • 5.  RE: what means Valid and Protected SSIDs ( WIPS )
    Posted Apr 12, 2018 04:41 AM
    i want to turn off ssid 1
    permit  list - ssid 1, ssid 2 , ssid 3
    block list - ssid 4
    becouse There is another office ssid near our office.
    so i want block my test ssid and unblock another office ssid
  • 6.  RE: what means Valid and Protected SSIDs ( WIPS )
    Posted Apr 18, 2018 03:20 AM
    I FIND IT !!
    I configed default profile and checked " Protect SSID" and "Detect valid SSID Misuse" .
    last , add ssid4 ( i wanted block ssid ) in Valid and Protected SSIDs.
    so i try connecting ssid4  , I CAN'T connect ssid4 and I Can connect ssid1,2,3
    thank you for reply my post~!
  • 7.  RE: what means Valid and Protected SSIDs ( WIPS )
    Posted Jul 05, 2018 11:59 AM
    I encountered the same problem, I need to block ssid which is not mine
    SSID 4 was from your controller or from next office controller ?
    Regards
    Rafi
  • 8.  RE: what means Valid and Protected SSIDs ( WIPS )
    Posted Jul 06, 2018 06:16 AM
    Hi
    SSID 4 is from my controller
    It is test Lab ssid
    anyway
    If you want block another ssid ,Enter the SSID you want to block into the Valid and Protected SSID
    Or
    Dashboard > Security >Click on the SSID to block > Reclassify > Rogue> Reclassify button
    in my case , I applied second way in my site
    Please refer to the capture below.
    I hope it helps.
  • 9.  RE: what means Valid and Protected SSIDs ( WIPS )
    Posted Jul 08, 2018 01:24 AM
    Thank you for your replay,
    please let see if i undestood you corectly,
    If i want to block SSID (whice is not from my controller) like private router or private hotspot and the aruba controller classifiy him as suspect ruge i need to write SSID name in "Valid and Protected SSID"  ?
    Because the "Valid" i thought that the meaninig is oppiste.
    About second option by default Aruba   dont block rogue AP, how can change this ? do you have any procedure ? (if you have step by step it will be fabulous)
    Is it posibale to block AP according to his mac address ?
    I read the IPS manual but unfotunately i didnt understand how ?
    Basically i cant do it  because i have  another wifi vendor in my campus, and since Aruba see  him wird and wifi he classify him as ruge.
  • 10.  RE: what means Valid and Protected SSIDs ( WIPS )
    Posted Jul 08, 2018 10:14 PM
    As you know,
     -> "Valid and Protected  SSID" is IDS Unauthorized Device >Adbanced's option.
     -> I think so too
     ->I hope the screenshot below helps.
    -> I dont know ...sorry..
    < my config screenshot >
    If you click finish button at first , sometimes never ending finish loading
    but check the All profile > IDS
    It is already configured.
    I think it is bug .
    you finish wizard , you need move to Dashboard > Security page
    and Reclassify Interfering AP
    Dashboard > Security >Interfering AP> Click on the SSID to permit> Reclassify > Authorized> Reclassify button
  • 11.  RE: what means Valid and Protected SSIDs ( WIPS )
    Posted Jul 15, 2018 02:25 AM
    Thank you very much,
    Sorry for the delay i was OOO for a few days,
    So to block SSID i need to write SSID name here ->  -> "Valid and Protected  SSID" is IDS Unauthorized Device >Adbanced's option.
    Am i right ?
    I couldnt find "Adbanced's"  option my version is 6.5.3.3
    Please see attached screenshot
    Regards
  • 12.  RE: what means Valid and Protected SSIDs ( WIPS )
    Posted Jul 16, 2018 08:32 PM
    hello~
    You found it exactly.
    but If you can't find it, check your wips license .
    I heard that the menu is not visible without a license.
  • 13.  RE: what means Valid and Protected SSIDs ( WIPS )
    Posted Jul 16, 2018 11:51 PM
    Ok, i will try this, i have a few SSID which is not mine (not from my controller)
    much obliged
    Regtards
    Rafi
