Under your WLAN settings. In the General tab, expand advanced settings. Expand Beacon Rate and you can set it on 2.4ghz and 5ghz.
You will also need to at least be on version 8.9 to set these.
Dustin Burns
ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
Original Message:
Sent: Feb 17, 2022 03:06 PM
Subject: Where beacon interval setting in Aruba Central?
Where can I modify the beacon interval in Aruba Central?
Thanks!
Jose Gonzalez
